ABS Light
Old Jan 16, 2007 | 02:41 PM
crhixon's Avatar
crhixon
Default ABS Light
My ABS and Brake warning lights both stay on. Also the Speedo doesn't begin to work until after 19mph. Im not sure if they are related. Any ideas what's causing this?
Old Jan 16, 2007 | 02:57 PM
mojo's Avatar
mojo
Default RE: ABS Light
It sounds like two seperate things. For the Brake Light check simple stuff (light bulbs, both tail and third light) also check fluid levels and wheel sensors. The speedo problem sonds like a snaped cable or the speed sensor is bad. If it is a bad sensor that might affect the ABS sensor because the computer can't tell how fast the truck is moving.
Old Jan 16, 2007 | 08:53 PM
1980blackfiveoh's Avatar
1980blackfiveoh
It is most likely the speed sensor in the rear diff.
Old Jan 16, 2007 | 10:23 PM
mopar98's Avatar
mopar98
Check the rear wheel speed sensor it's on top of the rear dif.
RWSS is the most likely cause.
Old Jan 17, 2007 | 12:37 AM
TMS Bill's Avatar
TMS Bill
+1 ... 100% certain this is the problem. Classic combination of symptomsfor a bad RWSS.
Old Jan 17, 2007 | 12:05 PM
crhixon's Avatar
crhixon
Thanks for your help. I ordered the part and he said it would be here Wednesday afternoon. My Dodge dealer wanted $55 for it, but my local parts store sold it for $30 with a lifetime warranty. I'll let you know after I replace it.
Old Jan 18, 2007 | 11:55 AM
crhixon's Avatar
crhixon
I replaced it last night, everything works. Thanks for your help.
