RE: Seatbelt Light Stays On
yup if that plug is unplugged.. it'll stay on
quick fix,if it comes back on again, get a strip of black tape an apply to light in dash or take the light out j/k i do know when its really cold out my dome light switch in the door freezes an when i open my door the lights dont come on till i wiggle it loose cold wether might have a factor in it
I never even noticed a seatbelt light in mine:D
i just bought an 04 1500 crew cab 5.7 hemi and the seat belt light has been on since i bought it im planning to go out of town with it so i'm gona get it checked out , but i tried unpluging the wires under the seat and the light and alarm still stayed on and its p#%^ing me off
Mine is due to something in the buckle not always syncing. As it comes on goes off all day long if you push on it or wiggle the seatbelt it will go off. Before my warranty ran out when I had it in the dealer and didnt seenm to want to fix it because the seatbelt was in fine operational working order.
I'm about to just pull the bulb I know when my belts on. |
Mine is driving me crazy, too. I figured out how the switch works, and reworked it to start off circiut closed and pulling the belt opened the circuit, and starting off circuit open and pulling the belt closing the circuit.... I finally did the tape thing...
Originally Posted by MagnumVP
(Post 666893)
99 Dodge Ram Quad Cab
For 3 days now the Seat Belt Light stays on all the time. I have checked the fuse and everything looks good. Have played with the seatbelt itself by just plugging it in and unplugging it. Done the same thing to the passenger side.. just in case. What else could be the issue? Nothing else seems to be effected. Not sure if this matters, but it has been 20 degrees recently at night and even freezes water left inside. This occured after the 3rd day of the freeze.[/align] |
problem solved
(Post 666893)
Seven year old thread?
I've got a similair dilemma, but I had switch the seats with seats from a 2001, but were the same seats, no power or heat or anything, and had different connections, ever since I swapped them the seatbelt light is on.
