front end clunck
Old Jan 18, 2007 | 03:31 PM
smity9's Avatar
smity9
Default front end clunck
i got a clunck from the front end it has been getting worse for the last few months. i took it in and they sayed it was the ball joints on the passengers side but it feels like alot more then that and ive crawled underneeth and everything seems tight i put new rancho shox on bout a year ago now with a 2" spacer. wondered if anyone could give me any sugestions. cause its gettin bad and i can feel it through my foot when its on the floor.
Old Jan 18, 2007 | 05:26 PM
mojo's Avatar
mojo
Default RE: front end clunck
Is it one clunk, when does it happen most, fast slow, turning, what kind of truck, 2 or 4 wheel drive? ball joints can sound like that and the only real way to test is to jack up the truck slide a pry bar under the wheel and lift up and down, if you feel excesive play or can see the joint move up and down then its bad. Swaybar endlinks can do that, swaybar bushings on the frame can do that espesially if you feel it on the floor boards, shock mounts, tie rod ends, wheel joints, bearings, axles, ujoints. Please be more specific.
