replacing carpet
Old Jan 25, 2007 | 11:42 PM
White Ram's Avatar
White Ram
Default replacing carpet
I'm going to replace the gray carpet in my '96 ext. cab 4x4.
Anybody have advice on aftermarket suppliers?
Old Jan 27, 2007 | 01:43 AM
TurboLion's Avatar
TurboLion
Default RE: replacing carpet
..there are a lot of companyson the internet that sells it..I ordered it from here, http://www.motorsouthcarpet.com/Carp...a/Default.aspx
because of the good price and quality product and original fit.[8D].click the above link and surf around it. You can find samples of different color tones or original. The guy there said, there is a difference in carpet dealers out there..suggest to get a pre Molded one that fits like a glove..I also orderedan insulation pad for heat and road noise..good luck..and heres another link to check out..
http://www.stockinteriors.com/Model....c=Dodge_Carpet
Old Apr 13, 2008 | 08:48 PM
nedcharter's Avatar
nedcharter
anyone else try replacing their carpet?
Old Apr 13, 2008 | 09:40 PM
citygasdude's Avatar
citygasdude
I replaced my carpet in a full size suburban all the way to the back. I agree the premolded is the way to go. I also had a punch with a screwdriver handle to help find the seat bolt holes in the floor under the new carpet and also found that a hooked razor knife, the one that looks like a beak or a claw worked pretty good for cutting a x over the hole for the seat frame bolts after finding hole with the punch. Good luck and you will like the finished product!!!
Old Apr 14, 2008 | 04:21 PM
nedcharter's Avatar
nedcharter
other than the couple places listed above, anyone know of a good place to get carpet from?
