Which gives most power?
Old Jan 30, 2007 | 01:07 PM
HankL's Avatar
HankL
Default RE: Which gives most power?
Try to buy your aftermarket intake from a seller who will let you return it 'no questions asked' including paying for return postage.
Based on these volunteers who tested aftermarkets intakes on a rear wheel dyno, it is unlikely either of those those intakes will give a real gain:
http://www.lxforums.com/board/showthread.php?t=14140
but it is better to do a 'two truck test' with real acceleration on a dragstrip, or a deserted and safe stretch of highway to evaluate intakes. Two trucks accelerating up a half mile stretch of steep hill is even better.
It would be easy to do a RELIABLE test of any two air intakes at the
dragstrip.
The way to do it would be to get two nearly identical trucks. They don't
have to be exactly identical but the closer the better.
The two trucks would line up against each other at least 4 times and
preferably 8 or more.
The first half of the runs one truck would have the air intake
and the other would have the stock air intake. After each pass
the drivers swap trucks. Then for the second half of the passes
the two trucks would swap intakes.
In making comparisons it is better to look at terminal speed rather than ET,
but subtracting 60 foot times from ET and comparing those is worthwhile too.
If the air intake really makes a average gain in terminal speed on both trucks
when installed that is pretty reasonable proof.
You might ask yourself:
Why doesn't each air intake maker hire an independent lab to do this and
verify that their intake is superior?
If you do 20 runs instead of 8,
and if the air intake makes a gain in terminal speed on 19 of those 20 runs,
then you are approaching the kind of proof scientists and MD's are supposed to
have before they 'publish' a fact in a magazine.
They wouldn't even have to hire a 'lab'.
Two of the following 'straight shooting' automotive writers (James Dulley,
Dan Neil, Steve Dulich, Rick Ehrenberg) have records that prove their
opinions can't be bought and could probably be paid a nominal
fee & travel expenses to face off against one another in a test.
A side benefit of the above test is that you could also settle bets as to
which of the two drivers was better, which can be fun. Killing two birds with the same stone, so to speak.
A properly designed air intake can give modest increases of torque and
horsepower at wide open throttle - but sometimes this comes at the cost of
increased noise or filters that get clogged with bugs and dirt faster.
If you are willing to tolerate more noise, in nearly every case you can
build a better air intake than you can buy.
This post has a Part II about the cheapest way to test any air intake.
Don't want to do testing and want a shortcut toward an effective
air intake?
Well, in a nutshell just remount your stock air box so that it will suck air
out of the cavity behind the firewall and below the windshield where your air
vents presently get their air. This spot will give you cooler air, higher
pressure air, and it will not pickup bugs/road grit as badly as an inlet near
the front grill.
Why didn't your vehicle suck air from this spot in the first place?
Because with the interior cab air vent inlets there it allows A LOT of NOISE
to go into the vehicle's cabin.
As a matter of fact, most aftermarket air intakes
JUST MAKE EXTRA NOISE.
This extra noise convinces most owners
that they are making more horsepower - no kidding.
If you read enough auto postings you come to the conclusion that many young
owners are really after 'Excitement' not true vehicle performance you
can time with a stopwatch. The loud mufflers, the loud stereos, the
vibrations of hard shock absorbers, the unstable feeling while driving high
lifted suspensions - it is really more about excitement than performance. Note
many of these same vehicle owners are heavy players of video games.
In addition to the spot at the base of the windshield, at the front of the
radiator grille, and - surprise - a scoop at the top of the tire in the fender
interior are spots where high velocity air can be converted to high pressure.
Notice that I have NOT said to rely on dyno testing of air intakes...I have
said do road tests.
Why?
Because you can't really test an aftermarket air intake system on a dyno where
the vehicle is not moving and an electric fan is blowing air at the radiator.
This makes it SO EASY TO CHEAT that you can make any air intake show a HP
increase on the dyno graph. Don't trust any dyno graph that claims to show an
aftermarket air intake horsepower gain. Realistic airflow around the vehicle
is critical to seeing whether it really works.
Note that KN Filters lists how independent laboratories verify their air
flow claims and their performance claims, but there is not a link to where an
independent lab has verified any MPG improvement claim. That is because the
engineers at KN Filters know that any MPG gain or loss that a customer reports
is really just 'random variation.' But that does not keep KN from quotes such
as 'Customers report 1-2 better MPG.' Note how that is 'literally true' but
not 'scientifically valid.' Those are known as 'Weasel Words' in the
advertising trade.
http://www.knfilters.com/testmethod.htm
http://www.knfilters.com/powertesting.htm
Old Jan 30, 2007 | 01:40 PM
hasersys's Avatar
hasersys
Lol about that whole stock intake tward the windshild an vent. The reason im looking into a new intake is do to the fact that a auto shop broke my stock box. They had snapped the plastic holding the metal clamps in the back of the box. The only way to get the back of the box to close is with ducktape but i hate how it looks so i have left it untill i get a new intake. So from what Hankl said i should be getting cooler air. Well that may be the case but he also said they don't put it there in the first place because of how much nocie it would make AND Yes IT makes tons of noise. Actualy kinda annoying. lol
