Need to change the heater core
Old Jan 29, 2007 | 01:50 AM
nateblong's Avatar
nateblong
Default Need to change the heater core
Has anyone replaced the heater core on a 2000 5.9 liter. I was wondering if I really need to unhook the A/C lines to do it. I figure I do but whanted to check first. Thanks.
Old Jan 29, 2007 | 03:11 AM
rollerstud98's Avatar
rollerstud98
Default RE: Need to change the heater core
just have to get the lines off the heatercore under the hood, then all the **** under the dash starts, thats the tough part, not to much room back there, you may want to remove the airbag give yourself a little more room
Old Jan 29, 2007 | 01:49 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
The A/C lines never need to be removed unless it is for work on the A/C system. And only then the work should be performed by a trained and certified technician with the right tools.
Old Jan 30, 2007 | 01:34 AM
nateblong's Avatar
nateblong
So you are sure that I do not have to discharge the A/C system to change out the heater core. The Haynes manual states that the system needs dischared and the lines need unhooked at the firewall. Have you changed a heater core on a second gen? Im just trying to save myself the hassle of discharging, unhooking lines, getting new gaskets and then recharging the system. Thanks alot
Old Jan 30, 2007 | 03:44 AM
rollerstud98
i have done mine, and also saw that it said to remove them but we never did, you can do it with out doing that
Old Jan 30, 2007 | 04:04 AM
dodgerules86's Avatar
dodgerules86
Just curious... why are you going to change your heater core?
Old Jan 30, 2007 | 04:46 AM
nateblong's Avatar
nateblong
Coolent had neven been changed when I bought the truck. When I flushed the system the core started leaking.....film on the windsheild...drips of coolent on the passengers side floormat. definitly the heater core... had the same problem bout 5 yrs ago with my 91 daytona....had to unhook the A/C to change the core on that car..
Old Jan 30, 2007 | 04:48 AM
nateblong's Avatar
nateblong
Thank you rollerstud I'll try replacing it without unhooking the A/C l
ines
Old Jan 30, 2007 | 04:51 AM
dodgerules86
I was just wondering, because some people think they need to replace their heater core just because their not getting enough heat (and they haven't tried flushing the core).
But since it's leaking.... have fun [:'(]
Old Jan 30, 2007 | 05:01 AM
rollerstud98
no problem, you may want to remove the compressor to get the lines out of your way though, just to make it a little easier workin right there
