Truck is still dying ***FIXED***
Old Feb 1, 2007 | 05:41 PM
BradBeyer's Avatar
BradBeyer
Default Truck is still dying ***FIXED***
ok I have done alot of searching and have tried the suggestions on here like:
[ol][*]taking off tb and cleaning well[*]checking for vacuum leak[*]plenum[/ol]
I am still having problems that after the truck is warmed up that it dies when you let off the gas...sometimes. I thought it was gong to be the tb it was pretty dirty but it helped but did not cure the problem.
My question is do you think it could be my IAC even though I am not getting a CEL?
Thanks Brad
Old Feb 1, 2007 | 06:55 PM
ddog737374's Avatar
ddog737374
Default RE: Truck is still dying
whenI first bought my truck, when I came to stoplights and sat their for a little bit my truck started to die but if i gave it some gas it would fix itself it turned out to be a bad O2 sensor.
Old Feb 1, 2007 | 08:11 PM
94 red ram's Avatar
94 red ram
egr solenoid
Old Feb 1, 2007 | 09:53 PM
TMS Bill's Avatar
TMS Bill
Could still be the TPS ... pretty simple (and relatively cheap) fix. O2 sensors ... possible. They can be cleaned as well.
Old Feb 2, 2007 | 11:15 AM
BradBeyer's Avatar
BradBeyer
How do you clean O2 sensors?
ddog737374 did you have a CEL on when you changed your O2's?
Thanks Brad
Old Feb 2, 2007 | 01:13 PM
ddog737374's Avatar
ddog737374
nope the CEL never came on
Old Feb 2, 2007 | 02:43 PM
TMS Bill's Avatar
TMS Bill
Brake cleaner and a toothbrush. Never had to do it myself (yet) but I've read here that sometimes cleaning them can work instead of replacing them ... but not always.
Old Feb 2, 2007 | 03:53 PM
BradBeyer's Avatar
BradBeyer
The other thing I forgot to metion is it is hard to start sometimes after it is warmed up...have to give it gas
Old Feb 5, 2007 | 12:16 PM
BradBeyer's Avatar
BradBeyer
I fixed the problem this weekend...it was the IAC. I put in a new one and it has never ran this good before.
Thyanks for all the help guys...you are the best
Brad
