15 inch rims
Old Feb 7, 2007 | 02:50 AM
Evolve's Avatar
Evolve
Default 15 inch rims
Will a 15in rim fit on a 97 Ram 1500? If not, then what sizes are approp?
Old Feb 7, 2007 | 03:36 AM
padodgeram's Avatar
padodgeram
Default RE: 15 inch rims
cant see why not , im running 16 " rims on my 96 and my friend running 16" rims on his 97 ..as long as the bolt patteren is the same.
Old Feb 7, 2007 | 03:56 AM
motorider228's Avatar
motorider228
yes it will. my 98 has 15's on it and 33's
Old Feb 7, 2007 | 04:15 AM
padodgeram's Avatar
padodgeram
what part of cant see why not didntyou get ? hell but 12" rims on as far as i care ...i did not say it wont fit...
Old Feb 7, 2007 | 04:36 AM
motorider228
hmm you got offended when I wasn't even talking to you. Clean the sand out of your vagina please.
Have a wonderful evening.
Old Feb 7, 2007 | 05:00 AM
padodgeram's Avatar
padodgeram
OH BOY...... see at the bottom reply to ? thats my name you replied to...
Old Feb 7, 2007 | 05:07 AM
motorider228
Padodgeram, It just says that when you hit the reply button. When most people are replying to someone they quote the person or start their post with the persons name. Even if I was replying to you, I said nothing confrontational so you need to learn to handle what people say better.
Edit: I hit the fast reply button at the very bottom of the page this time and it still says your name.
Old Feb 7, 2007 | 10:43 AM
dhvaughan's Avatar
dhvaughan
evolve, check the sticker inside your drivers door and it should list your original factory sizes. (it doesn't really matter but its just nice to know). i think your 97 had 15's. you can go with bigger/smaller wheels or tires up to a size limit of about 32-33 inches tall (wheel + tire), however it will cause your speedometer and odometer to be off. you can correct that in a couple of ways depending on whether your speedo is electronic or gear driven. if you are considering aftermarket wheels be sure of your bolt pattern and BACKSPACING. do a search here for backspacing - this is very important as it controls whether you get rubbing or not and whether or not your wheels STICK OUT and look silly.
Old Feb 7, 2007 | 02:39 PM
TMS Bill's Avatar
TMS Bill
ORIGINAL: padodgeram
On top of all your indignation that someone had the audacity to post an answer to a question that you had already responded to ... you didn't correctly answer the question. These trucks come with 16" rims ... installing a 15" rim CAN cause problems because they are SMALLER and rub on the brake caliper on some trucks. Evolve didn't ask if he could run 16" ... he asked if he could run 15".
Old Feb 7, 2007 | 02:56 PM
Tani1500's Avatar
Tani1500
yes u can run 15's they wont fit on the 99+ rams because the swiched caliper sizes. now stop the baby bitching, its rediculous
