Best way to clean engine
Old Feb 9, 2007 | 03:49 PM
Zachtk8702's Avatar
Zachtk8702
Default Best way to clean engine
My engine compartment is a mess.... From mudding its just a coat of brown... Is there any way to restore that stuff to look a bit nicer? Other than a pressure washer of course.
Old Feb 9, 2007 | 05:03 PM
Silver_Dodge's Avatar
Silver_Dodge
Default RE: Best way to clean engine
Engine degreaser, a rag, and lots of time and elbow grease. Otherwise, pressure washer is good, just watch what you spray.
Old Feb 9, 2007 | 05:28 PM
RM_Indy's Avatar
RM_Indy
I would be carefull with engine degreaser
I got carried away spraying mine with it and removed the coating off the frame rails on passenger side. Ended up removing all the coating from firewall forward & painting it with POR15 cause it started to get surface rust almost immediately. Painting frame/suspension looks great but man it was a ton of work.
