Mileage and Lowering - New Dodge Owner
Old Feb 14, 2007 | 07:55 AM
RetroCow's Avatar
RetroCow
Default RE: Mileage and Lowering - New Dodge Owner
Liftgate is the way to go!
Oh, and the milage would be better if you had a Cummins! 21mpg highway
Old Feb 14, 2007 | 12:15 PM
landarch96's Avatar
landarch96
Dodge issued a service bulletin on the subject. People were haveing problems fitting the bed rails under fifth wheel trailers. So Dodge offered a service bulletin to replace the rear blocks with smaller ones. I'm not real sure what the size difference is but I think it's somewhere around 2". Ask your local stealership to pull up the list of bulletins and you may be able to get it done on their dime.
Old Feb 14, 2007 | 03:28 PM
1969roadrunner's Avatar
1969roadrunner
Ok, take a look at the price here too. You can get a bed crane for a couple hundred dollars, or you could bulid your own for even less - if you start lowering stuff and cutting and replacing and all that, you are looking at alot of time and a lot of money, and what happens if you mess something up and have to totally replace it?
Find a way to help bring the load to the truck. That is a lot easier than bringing to truck down to the load...
Old Feb 15, 2007 | 03:32 PM
bbobb's Avatar
bbobb
Dodge does have a stock lowering kit. Two shorter blocks for the axle. Except the TSB doesn't require Dodge to pay for it! The kit alone is almost 900$!!! The blocks must be gold...
Old Feb 17, 2007 | 03:56 AM
RamMan_8520's Avatar
RamMan_8520
put somes pics of the truck on her and if you really want a lower truck just like "jisthangin01" said ill trade you 1500
Old Feb 17, 2007 | 05:34 AM
radwebster's Avatar
radwebster
no offence, but if you want a big, bad 2500 four by four, you're gonna have to deal with it. what size tires are on it now? if they were replaced with a larger size you can go back to stock or smaller than stock and that'll lower it some.
Old Feb 17, 2007 | 05:55 AM
Cereal Killer's Avatar
Cereal Killer
I thought this disorder was only suffered by S10 owners [&o]
