Tranny: Cold Start
Old Feb 13, 2007 | 08:00 PM
palo35's Avatar
palo35
Default Tranny: Cold Start
Issue: Rebuilt Tranny just over a year ago, Issues since - bad govenor and pressure solinoid- both replaced. No problems until winter came. Once the temp drops below say 25 degrees and the truck is off for over 4 hours, putting the transmission in gear, I get no response. Shift thru all the gears, no response. Once truck has been running at idle for about 5 minutes, all is fine. I'm thinking possible tourqe converter or pump is bad. Good new is that its still under warrenty. Taking it in tomorrow but looking for ideas on what the possible cause could be. [X(]
97 dodge 2500 V10
135,000 miles
11,000 on rebuilt tranny.
Old Feb 13, 2007 | 09:39 PM
dsertdog56's Avatar
dsertdog56
Default RE: Tranny: Cold Start
Be sure and post what they found...sounds like a plugged filter or cooler/check valve.
