4WD light wont go off!!!
Old Feb 14, 2007 | 03:07 AM
Dodge ram it's Avatar
Dodge ram it
Default 4WD light wont go off!!!
I know its not in four wheel, but the darn light is staying on all the time. What is causing this?
Old Feb 14, 2007 | 11:04 AM
DieselDemon's Avatar
DieselDemon
Default RE: 4WD light wont go off!!!
Should we guess on the year, model, engine, etc?
[IMG]local://upfiles/12792/5ADB42BDBD1D47F0A2FC64E76ED9CF24.jpg[/IMG]
Old Feb 14, 2007 | 02:46 PM
Dodge ram it
sorry.....
95 1500, 4X4, 5.9L, Automatic.
Old Feb 14, 2007 | 10:11 PM
dhvaughan's Avatar
dhvaughan
4wd light is turned on/off by a switch on the end of the CAD, which is on the back side of the front axle, passenger side. it has a vacuum looking thing on one end with vac lines and an electrical switch on the other. unplug the electrical connector and see if the light goes off. if it does NOT go off, then troubleshoot those wires. if the light does go off, then troubleshoot the switch. start by spraying the connector and switch with wd40, and checking for damage, cleaning out mud, rust, etc. test switch with ohm meter while engaging/disengaging 4wd. the switch is supposed to be turn on/off by the internals of the cad. search on cad for recent posts that include nice diagrams.
Old Feb 14, 2007 | 10:22 PM
Dodge ram it
dhvaughanthanks for all the good info! Ill give it a try, hope its a simple/cheap fix.
