Engine stalls
I tore my bathroom apart to find it, but I finally did. The article basically says that the improper tourqe converter/flexplate combination will cause the engine to cough and die. It gives this number for dependable dodge if you want to try calling them 1-818-883-9060
Good Luck
Good Luck
any idea what your factory stall speed was vs your new tc ?
what about the lockup type ?
http://www.tciauto.com/Products/AMC/
http://www.moddedmustangs.com/forums...er-vt5551.html
http://www.gnttype.org/techarea/tran...onverters.html
http://www.summitracing.com/streetan...BD43F224310%7D
I removed the stock torque converter and replaced it witha 166K 2250-2350 TC. When I open the throttle she begings to cough. I finally got a code P1391 which is intermittenent loss of CMP or CKP. The minute I shift into gear she stumbles and stalls, but if I pump the gas she will stumble and cough. Im going to replace the IAC and the TPS. They are stock and have never been replaced.
