POpping noise in while idleing.
Old Feb 20, 2007 | 12:13 AM
Terran's Avatar
Terran
Default POpping noise in while idleing.
I was sitting at the Dunks window today and i notice and popping sound from my engine compartment while it was idling, it sounds liek somone cracklign paper or somthing. Is that bad?
Old Feb 20, 2007 | 12:41 AM
dhvaughan's Avatar
dhvaughan
Default RE: POpping noise in while idleing.
i don't think its normal. is it skipping any or running rough. a grounding spark will make a snapping sound. you can usually see it a night, its a pretty blue color.
Old Feb 20, 2007 | 11:49 PM
Terran's Avatar
Terran
i looked the other night and didn't see anything, but i think i'll pull the heat sheilds off and see if they're causing it to ground (maybe too much Dielectric grease?)
Old Feb 21, 2007 | 01:15 AM
pashtrd's Avatar
pashtrd
I have a 2001 Ram and mine has always done that ( the 2 years i have owned it at least)
I dont know what it is either
Old Feb 21, 2007 | 01:44 AM
Zachtk8702's Avatar
Zachtk8702
I have a 2001 dodge ram 5.9L, mine does the same thing... Dunno what it is... . Maybe if yours is a v8 you might wanna try running premium.... I'm pretty sure its best for all v8's to runon premium... I can def tell a difference when I use it.
Old Feb 21, 2007 | 09:12 AM
Terran's Avatar
Terran
Running preminum isn't really an option, but i don't think it would really make a difference. It's like a crackling sond coming from the drivers side.
Old Feb 21, 2007 | 10:38 AM
topsites's Avatar
topsites
There is a type of noise I can think of that can be hard to trace and does no immediate harm, but good it isn't.
What I am thinking of is dry pulley bearings (or bushings) that emit a scraping sound, some will squeal, but not always.
The easy fix, but you have to be careful you don't get it on the belt, is to get a can of Wd-40 and insert that little red tube into the nozzle, then give each pulley a quick squirt of lube right into the part where it rotates.
If that doesn't fix it, you've done no harm and it usually quiets things down at least some (but watch the belt, don't get the wd-40 on that).
It's worth a shot, only takes a few minutes and is cheap to do.
Good luck.
Old Feb 21, 2007 | 08:57 PM
rango726's Avatar
rango726
mine does the same thing it kind of sounds like something is vibratingagainst the firewall. i just noticed it today it drive me nuts.
Old Feb 22, 2007 | 09:19 AM
Terran's Avatar
Terran
See this sounds like sombody crinkling paper. I only notice it one in a while, especially when it's warmed up.
Old Feb 22, 2007 | 03:00 PM
rango726's Avatar
rango726
i was listening to it again today and it sounds like popcorn popping but a bit faster i opened my hood and i cant hear it ?
