rad leaking, is there a patch?
Old Feb 23, 2007 | 01:27 PM
IndyRamMan's Avatar
IndyRamMan
Default rad leaking, is there a patch?
My rad has been leaking for a while, a few drops a day, but today it started leaking a lot, like a quart per few hours. I know the leak is where the bottom rad hose connects to the rad, i got the new hose, but if it is a crack in the rad, is there a patch i can put on there?
Old Feb 23, 2007 | 01:58 PM
bamory's Avatar
bamory
Default RE: rad leaking, is there a patch?
A good radiator shop can fix that for you, a friend of mineowns one and I really havent seen anything he couldnt fix in the way of leaks.I would get a quote first to see how much, may save some money If you take it out yourself. Or it may pay just to get a good 4 core.
Also never put anything inside your radiator except water and coolant, no stop leaks etc...etc....
Old Feb 24, 2007 | 01:42 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: bamory
yea, i dont fancy the stop leaks and whatnot, but im looking for an external patch possabily.
Old Feb 24, 2007 | 02:37 AM
bamory's Avatar
bamory
I would just take it to a local shop, when it comes to the rad, alot of things depend on that to stay cool........goodluck
Old Feb 24, 2007 | 03:21 AM
dsertdog56's Avatar
dsertdog56
The plastic tank is cracked, much cheaper to have it repaired with a new tank than patching or replacing the whole thing.
Old Feb 24, 2007 | 10:49 AM
trukr36's Avatar
trukr36
Best thing is to have a rad shop fix it, but, if you want a short term patch, get a roll of that steel putty found in most auto stores. It goes by different names but its a grey putty with black core that you pull a piece off the roll and roll it around in your hand until the colors mix, then press it into the hole/crack. Sets up fast, cures rock hard in no time. I've used this on rads before and it works great.
Old Feb 25, 2007 | 10:10 PM
damageddakota's Avatar
damageddakota
throw an egg in the mother ****er
Old Feb 26, 2007 | 01:24 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: trukr36
sounds like fiberglass resin
Old Feb 26, 2007 | 01:59 AM
dhvaughan's Avatar
dhvaughan
ORIGINAL: damageddakota
throw an egg in the mother ........
an egg ? i never heard of that one.
Old Feb 26, 2007 | 02:52 AM
dhvaughan's Avatar
dhvaughan
hmm, 4 egg whites. i'd heard of pepper, but not egg whites.
http://www.4x4review.com/tech/radiator.asp
