Can't Get Past 65mph Or 2500 RPM
Old Feb 26, 2007 | 02:26 PM
Nitroman's Avatar
Nitroman
Default RE: Can't Get Past 65mph Or 2500 RPM
Sorry 'bout the lack of information. I let the truck warm up then took it for a spin for a few miles to get heat into everything. In park I slowly increased the throttle until it was at 4000 rpm. I did not unhook the pre-cat O2 sensor. BUT! I did find out something really interesting: only one pipe has a cat! It appears someone removed the cat and o2 sensor from drivers side pipe and replaced those parts with a simple piece of exhaust pipe. I see the plug for the o2 sensor zipp-tied out of the way. One o2 sensor is plugged in. I should try to take a pic of this, but it is colder that a witches tit outside and don't want snow landing on my camera. I'll try to get this into the shop within the next few days. I have new plug wires, plugs, and the speed sensor that fits into the transmission (TPS did nothing for the tranny shift-up-shift-down syndrome). Also bought a new tranny filter while I was at it and synthetic tranny oil.
Checked the air filter and it is clean, but will replace it anyways.
Old Feb 26, 2007 | 03:25 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Nitroman
Ok, let's see. I bought it from the dealership and it had had a tune up, the usual dealer stuff, back in August. SO that would be six months ago. Hmmm. Time to do the tune-up then. I'll try that O2 sensor trick and see what happens. I will try to see how high I can rev it....within reason. Maybe 4,000 rpms.
There is no such thing as a tune-up anymore. The dealer is taking you for a ride. Take your truck to a muffler shop and have them perform a pressure check on the cat. That was the problem with my truck, which I bought used.
Old Feb 26, 2007 | 03:46 PM
Zeppelinrocks's Avatar
Zeppelinrocks
how do they do a pressure test on the cat? I think mine is goin bad and i want to know before i replace it.
Old Feb 26, 2007 | 03:58 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
ORIGINAL: Zeppelinrocks
They use a torch to cut a small hole in the exhaust pipe before the cat. Then, they connect a special clap that pressurizes a line running to a meter, which indicates how much backpressure there is from the cat when the engine is running. The then weld the hole shut. I doubt there would be a charge involved as it takes about 10 minutes.
Old Feb 26, 2007 | 04:12 PM
Zeppelinrocks
thanks, time to start calling some muffler shops
Old Feb 26, 2007 | 04:36 PM
spiral72's Avatar
spiral72
"only one pipe has a cat! It appears someone removed the cat and o2 sensor from drivers side pipe and replaced those parts with a simple piece of exhaust pipe. I see the plug for the o2 sensor zipp-tied out of the way. One o2 sensor is plugged in."
Well, that's kind of stupid. So the ECM has absolutely no idea what's going on. I can't believe it didn't show before this!
Old Feb 27, 2007 | 04:51 AM
Captain Squalus's Avatar
Captain Squalus
Had the same problem on a 88 318 it was a combination problem of a weak fuel pump and old fuel filter.
