Dual Battery Setup
Old Feb 24, 2007 | 09:01 PM
DodgeRAmPower's Avatar
DodgeRAmPower
Default Dual Battery Setup
I was thinking about doing a dual battery setup... i would use a hellroaring isolater / combiner, with 0 to 2 guage battery wiring, i would wire two batterie's negative's together (ground) (starter battery & yellow secondary optima deep cycle battery). Then i would mount the isolater, and run fuses between each of the two batteries postives to the isolater, and get the hellroaring remote kit and wire it in, and i would be set? any comments / concerns on this setup, and any ideas to add to this setup or have any ideas on a different setup...i would greatly appreciate
- DodgeRAmPower
Old Feb 24, 2007 | 09:14 PM
radwebster's Avatar
radwebster
Default RE: Dual Battery Setup
https://dodgeforum.com/m_615004/tm.htm
