help weird brake problem
Old Feb 24, 2007 | 09:25 PM
ozzy460's Avatar
ozzy460
Default help weird brake problem
my wife has a 95 3/4 4x4 ram lifted big tires 318 5 speed. have owned it for 2 years and always had a pull to the left and when you hit the brakes it got squirrly. always thought it was the lift and told her to suck it up. well its been getting crappy milage 12 to 14 and when she hit 5th gear it would bog right down, the other day she hit a big pothole the brake light came on it stopped pulling to the left and when she hit the brakes it didn't have the stopping power but did not get squirrly. when brake lights on its drives fine when brake light goes out its back to the same old crap. whats up with this thing. thanks
Old Feb 24, 2007 | 10:42 PM
DieselDemon's Avatar
DieselDemon
Default RE: help weird brake problem
If it's a 95' with original calipers, they need to be replaced I assure you...lol.
Have you checked the brake fluid level? Are your rear drums out of adjustment? Have you ever worked on brakes before? Not breakin chops, just askin in case we get into details..LOL.
Good luck with your ride.
Old Feb 24, 2007 | 11:11 PM
ozzy460's Avatar
ozzy460
well when i did the lift in 05 i extended the brake lines, in 06 i put all new rear drums, hardware and brake including ebrake cables. haven't touch rear brake since 4/ 06 still did same thing then. truck does have orig front calipers. i have done right side wheel bearing twice in 1 year less than 4000 miles.
Old Apr 13, 2007 | 07:29 PM
jimsxj's Avatar
jimsxj
Did you have the new drums turned and cleaned? If you did not, you will need to replace your rear shoes and turn and clean the drums.
