I want to swap engines ...
Old Mar 2, 2007 | 12:55 AM
shaker's Avatar
shaker
Default I want to swap engines ...
I hope someone can answer this...
I have a ram 1999 1500 4x4 reg cab, short box with the larger V8.It's the 5.9 liter. Love the truck, but the engine is starting to fail. I have over 180K miles on her.
Anyway, what I'd like to do is swap a smaller v6 in its place. Do they have similar footprints or is there a ton of modification I'd need to do? And can anyone recommend an engine?
Let me know if I'm way off base. This is a project for me and my soon-to-be-driving-full-time son.
thanks,
JC in Iowa
Old Mar 2, 2007 | 01:24 AM
94 red ram's Avatar
94 red ram
Default RE: I want to swap engines ...
if you want it on the road soon then go with another 5.9 spend the money for another used engine, if you would go with an v6 then i am sure you would have ot go with an v6 wire harness for the most part and an v6 comp and different fuel pump
Old Mar 2, 2007 | 01:31 AM
radwebster's Avatar
radwebster
why do a V6? you will lose a ton of power and gain only minimal mpg's. if anything, swap in a 5.2L V8...it will be a direct swap for the most part. plus you will get a very solid, strong motor. and the difference between the V6 and the 5.2L in terms of mpg is very small.
Old Mar 2, 2007 | 01:53 AM
97Ram2500's Avatar
97Ram2500
I had a Dakota (lighter truck)with the v6 saw top mileage with a 5 speed of maybe 17 highway most often 14-15 mixed driving, my 5.9L 2500 (heavy truck) gets around 14 highway and 12 mixed. I would never go with the smaller engines would not be worth it to me just my .02
Old Mar 2, 2007 | 02:13 AM
Socha_62's Avatar
Socha_62
Screw v6, 408 Stroker
Old Mar 2, 2007 | 02:15 AM
shott8283's Avatar
shott8283
ORIGINAL: Socha_62
i like your style whiteshaddow
Old Mar 2, 2007 | 02:17 AM
TMS Bill's Avatar
TMS Bill
You love the truck (5.9 and all) but want to put a V6 in it ? You will HATE it! [:'(] A full size Ram 4x4 with a V6 ... even Dodge didn't do that from the factory.
Old Mar 2, 2007 | 02:20 AM
97Ram2500's Avatar
97Ram2500
I thought Dodge did have a v6 option for a reg swb. I had the v6 in a 2wd dakota and it wasn't enough power for me I was so wishing I had gotten a v8.
Old Mar 2, 2007 | 02:21 AM
94 red ram's Avatar
94 red ram
you couldnt take it off road even if u tried , but not try to bust your ***** man but v6 just wont really work
Old Mar 2, 2007 | 02:54 AM
radwebster's Avatar
radwebster
ORIGINAL: 97Ram2500
not 4 wheel drive
