So what do you guys think?
Old Mar 2, 2007 | 01:45 AM
junkman306's Avatar
junkman306
Default So what do you guys think?
I found this intake on ebay and it doesn't seem like too bad of a deal.
http://cgi.ebay.com/ebaymotors/94-95...QQcmdZViewItem
Old Mar 2, 2007 | 02:05 AM
tdmopar59's Avatar
tdmopar59
Default RE: So what do you guys think?
it should work pretty well and if the cone sux just swap it with a k and n
Old Mar 2, 2007 | 02:09 AM
shott8283's Avatar
shott8283
one of the best properties of aluminum is its ability to transfer heat.. thats why your rad. is made out of it.. and thast why K&N FIPK is made out of ABS plastic.. lower heat transfer characteristics.. although the price is something you cant beat.. remember.. you get what you pay for.. you should get better air flow .. but the cold air factor wont be as good as an FIPK
just food for thought..
Old Mar 2, 2007 | 02:18 AM
junkman306's Avatar
junkman306
ORIGINAL: shott8283
True. I figured whichever way I go I want to build a box around the filter and use the fenderwell duct to route the air into it.
Old Mar 2, 2007 | 02:20 AM
tdmopar59's Avatar
tdmopar59
wat if u used header wrap to keep the temperature under control
Old Mar 2, 2007 | 02:22 AM
junkman306's Avatar
junkman306
You could but either way with the filter being open under the hood you are still gonna suck up hot air.
Old Mar 2, 2007 | 03:01 AM
sbrunn9's Avatar
sbrunn9
I have that same intake on my truck I think i got it from the same guy on ebay. It works well, but like someone said you get what you pay for so it's no high end intake. It was rough gettin it on cause it didn't fit well, it was a little tall, and the bolt that they give you is too tall so i had to cut part of it down and use a washer to space the nut up. For that price you can't beat it but if I knew what I was getting before I bought it I would've spent a little more and gotten a better one.
Old Mar 2, 2007 | 03:15 AM
junkman306's Avatar
junkman306
Thanks for the info. I may pass on this one. I was just curious about it.
