oppinions on intake
i just put on the edelbrock triangle foam intake. it feels good up top, a little worse down low, and sounds better. all that was expected. whats your oppinion on this air cleaner? should i worry about air fuel mapping at all?
I have heard bad things about foam filters like that. Things like the foam getting sucked into the intake. Also never heard much good about their filtering ability.-
I also don't like that the top facing side is also foam. That means that if you have any moisture get by the hood-to-cowl seal, it will drip down on top of the filter and soak the foam, or worse drip into the intake.
the o2 sensor & map sensor will keep the mixture right... the only time you need to start worrying is when you go to heavy mods, then consider a custom pcm flash to match your setup.
ORIGINAL: Silver_Dodge
ORIGINAL: steve05ram360
