Front hub nut torque spec.
Old Mar 4, 2007 | 06:55 PM
skippy344's Avatar
skippy344
Default Front hub nut torque spec.
Hey Folks,
My '99 ram 1500 2wd has the rotor as one piece, not two. What is the torque spec for the hub nut? Back in the old days, we'd tighten them down to like 20lbs spin the rotor and retorque to 30 lbs.
My hub is NOT separate from the rotor, they are one piece.
Thanks!
greg
Old Mar 15, 2007 | 01:31 AM
skippy344's Avatar
skippy344
Default RE: Front hub nut torque spec.
Dealer tells me its 140 lb-ft.
Thanks,
Old Mar 15, 2007 | 01:51 AM
mtrider's Avatar
mtrider
the dealer obviously thought you have a 4wd truck.The method you thought should work fine on your 2wd.
Old Mar 15, 2007 | 02:01 AM
TMS Bill's Avatar
TMS Bill
The 2001 FSM shows the 2WD as having 2 piece rotor/hub assemblies.
(3) Install the new hub/bearing nut and tighten to:
² LD 1500: 251N·m (185 ft. lbs.)
² HD 2500/3500: 380 N·m (280 ft lbs.)
I have the 1998 FSM at the house ... since you have a 99 ... maybe it'll show something different.
Old Mar 15, 2007 | 09:33 PM
TMS Bill's Avatar
TMS Bill
Download this PDF file (right-click and "Save Link As ...") It is a complete list of hub/wheel/spindle nut torque values and procedures for a raft-load of vehicles.
http://vsmus-origin.skf.com/Files/Br...PDF/457377.pdf
Your truck year and model (1999 Ram 1500 2WD) is procedure DTA:
DTA Tighten hub nut while rotating wheel. Back off
and tighten again while rotating wheel. Back off
until .001-.002" of freeplay is measured at wheel.
