I give up.
Old Mar 4, 2007 | 11:49 PM
junkman306's Avatar
junkman306
Default I give up.
I tried all day yesterday to get my damn crank sensor off, but as usual everything thats supposed to be relatively simple ends up being too hard. Mine has allen headed bolts holding it on and theres some damn tube that goes from the exhuastmanifold right across the heads of the bolts so its a pain to get to. I can't go from the bottom cuz my exhaust is in the way and i'd have to take it all down to even get to it which is a job all in itself. So I give up. If anybody is ever in the southwest missouri area then let me know and i'll buy you lunch.
Old Mar 5, 2007 | 12:11 AM
nim81's Avatar
nim81
Default RE: I give up.
all you have to do is put a 3" body lift on your truck and shazam! its totally easy to get to.
if not then thats gunna be a *itch to get out.
im in south east missouriif u still want to buy me lunch
Old Mar 5, 2007 | 12:52 AM
junkman306's Avatar
junkman306
If you know how to do it come on over.
Old Mar 5, 2007 | 03:06 AM
SrpntHntr's Avatar
SrpntHntr
I had that same feeling with that same year and engine. The tube going from the exhaust to the EGR and the mounting bracket for the tranny fill are in JUST the right places. I ended up removing the bell housing bolt that holds the tranny fill and pushing it aside then used the appropriate sized allen socket on a wobble and extension. Came right out from the top. I used a magnet on the allen to hold the bolts and finger startedwhen I reinstalled. A mirror is a lot of help on this one too.
Old Mar 5, 2007 | 04:31 PM
Socha_62's Avatar
Socha_62
When I took mine off I noticed the dip stick was right in the way, it was kind of a pain but I have a body lift so that that hard. It would suck with no body lift.
Old Mar 5, 2007 | 04:42 PM
junkman306's Avatar
junkman306
ORIGINAL: SrpntHntr
Thanks for the info. I think i could've got it, but there is so much work to do just to get to it that it pissed me off. I'll try again wednesday. How hard is the plug to get to?
