Tranny Cooler lines
Old Mar 5, 2007 | 09:44 PM
sdguyman's Avatar
sdguyman
Default Tranny Cooler lines
Does anyone know where I can get replacement hoses for my tranny cooler? I need the lines that are between the radiator and the tranny cooler.
Thank in advance!
Old Mar 5, 2007 | 10:40 PM
dhvaughan's Avatar
dhvaughan
Default RE: Tranny Cooler lines
you could check your local parts store for replacements, but the cheapest thing to do is replace them with standard transmission hose and clamps. hose sells for about $3-$4 per foot. you will need about 3-4 feet. you will also need a 3/8 inch fuel line disconnect tool to get the old lines off at the rad.. if you cant just borrow one you can buy plastic ones for about $10 or less at parts store. you will need a tubing cutter to cut the flare off the pressure line, thats the one with the threaded check valve. throw the check valve away. you will also need to find a way to cut the crimped fitting off the return line. its the unthreaded one. a dremel tool with the little bitty cutoff wheels works good. dodge made this about 10 times as hard as necessary. here are some pics.
https://dodgeforum.com/m_717634/tm.htm
