O2 sensor and injectors
Old Mar 6, 2007 | 04:36 PM
BradBeyer's Avatar
BradBeyer
Default O2 sensor and injectors
Is there a way to check an O2 sensor with a volt meter? Like you do with the TPS (.7).
Which O2 sensor would you replace first or both at the same time?
How would anyone suggest cleaning injectors? Just buy the stuff off the shelf or is there another way?
Thanks for the info.
Brad
Old Mar 6, 2007 | 08:50 PM
TMS Bill's Avatar
TMS Bill
Default RE: O2 sensor and injectors
I left a link on the other thread that you asked about checking O2 sensors ... here it is again: http://www.gnttype.org/techarea/ecms...O2sensors.html
Check them ... if they work ... reinstall.
Cleaning ... I've heard brake cleaner and I've heard carb cleaner. Brake cleaner is pretty harsh but leaves no residue. Carb cleaner is closer to what they live with anyway but can leave crap behind. From what I read ... you have to clean the WHOLE sensor ... not just the part that goes in the pipe.
