would you replace timing chain w/water pump
Old Mar 12, 2007 | 04:24 PM
dhvaughan's Avatar
dhvaughan
Default would you replace timing chain w/water pump
01, 5.2, truck has 130k miles and water pump is shot. i'm replacing the water pump, thermostat, all hoses. Timing chain and sprockets are only another $55. would you replace them too ? i have a puller for the harmonic balancer, so it looks like just a little more work.
anyone know of a good reason not to do it ?
what would you do ?
Old Mar 12, 2007 | 04:35 PM
Racinfan83's Avatar
Racinfan83
Default RE: would you replace timing chain w/water pump
If I was tearing into it that far - for sure I would go ahead and do the chain. You'd feel mighty stupid if you did allthe other and a month from now the chain slipped and you had to take all that stuff back off again....
Old Mar 12, 2007 | 10:33 PM
TMS Bill's Avatar
TMS Bill
+1 ... go for it.
Old Mar 12, 2007 | 11:45 PM
Dodge4x4810's Avatar
Dodge4x4810
i'd do the chain too.
Old Mar 12, 2007 | 11:48 PM
habeba86's Avatar
habeba86
I'm jumping on the bandwagon and saying yes.
Old Mar 13, 2007 | 01:16 AM
lancelanz's Avatar
lancelanz
i agree might as well go ahead and do it. even if only for the peace of mind knowing that is a new chain. when my water pump went i didnt change the chain but i did have to replace the timing cover gasket.
Old Mar 13, 2007 | 11:51 AM
TPSDODGE's Avatar
TPSDODGE
deff a great idea it seems that they get slack around 160k, acording to the techs at my dealership
Old Mar 13, 2007 | 09:51 PM
Socha_62's Avatar
Socha_62
For the extra like 6 ot 8 bolts to take off, do it. Make sure get/rent a harmonic balancer puller. Thats about all you'll need.
Old Mar 13, 2007 | 10:58 PM
mopowar's Avatar
mopowar
Impact gun will make the job alot easier as well.
Old Mar 14, 2007 | 12:34 AM
steve05ram360's Avatar
steve05ram360
I'll go one farther... yes you HAVE to swap the chain... stock ones are junk and stretch over a short period of time 40k~50k miles and it's toast. piece of mind that the cam timing will not change is worth the extra effort to swap it.
