WOT fan noise
Old Mar 14, 2007 | 11:57 PM
jstnumber73's Avatar
jstnumber73
Default WOT fan noise
When i press the gas half to wide open throttle my truck sounds like a box fan hitting the plastic cage. I have a 97 1500 v6 3.9. pls help me with this problem. thank you in advance.
Old Mar 15, 2007 | 12:46 AM
TMS Bill's Avatar
TMS Bill
Default RE: WOT fan noise
Have you popped the hood and revved it by hand? You'll get a better idea of where the noise is coming from.
Old Mar 15, 2007 | 01:18 AM
jstnumber73
yes it seems to do it when its under a load not in neutral
Old Mar 15, 2007 | 01:33 AM
mtrider's Avatar
mtrider
Grab the fan blade(with the engine off)see if it turns.If not,the clutch is locked up...easy fix.
Old Mar 15, 2007 | 01:41 AM
morrgriff's Avatar
morrgriff
Maybe try popping the hood, set the parking brake and/or chock the wheels (safety first!) and power-brake in drive with someone off to the side looking/listening for the sound. Maybe a motor mount????
Old Mar 15, 2007 | 03:32 AM
ram51's Avatar
ram51
I had that same problem on my 00 Dakota took it to the Deal turns out my clutch on my clutch fan went bad.
Old Mar 15, 2007 | 09:52 AM
jstnumber73
Alright im going to replace the fan clutch. Thank you all! peace
