Growling sound from front not brakes ?
Old Mar 15, 2007 | 10:44 PM
LongBowHunter's Avatar
LongBowHunter
Default Growling sound from front not brakes ?
My son has a 99 ram 1500 2 w drive. It is making a growling sound from the front passenger side on left turns . also makes the same sound when braking I thought it was the brakes . I put new pads on todayI did not change the rotors they looked good . Pads could have lasted another 6 months but I went a head and replaced them. ANY IDEAS ????????
Old Mar 16, 2007 | 12:00 AM
padodgeram's Avatar
padodgeram
Default RE: Growling sound from front not brakes ?
have you check the bearings ?
Old Mar 16, 2007 | 12:32 AM
dsertdog56's Avatar
dsertdog56
Sounds like its time for hub bearings. Lift your front tires off the ground, grab a tire at the top and bottom and try to move it (wiggle). Any play is a sign of immenent hub bearing failure.
Old Mar 16, 2007 | 01:33 AM
LongBowHunter
OK if it is the hub bearingswhat kind of money am I looking at and are they built in to the hub or are the separate ?
Old Mar 16, 2007 | 01:41 AM
ramchrgr88's Avatar
ramchrgr88
maybe you ran over a lion or something....
Old Mar 16, 2007 | 01:58 AM
padodgeram's Avatar
padodgeram
www.advanceautoparts.com
www.autozone.com
get a good idea on $$$$
Old Mar 16, 2007 | 03:10 AM
IndyRamMan's Avatar
IndyRamMan
definatly time to change brake pads. Mine just started doing it today. what it is is either a warning tab that makes contact with the rotor when the pad gets low, or the pad is just so low that its actually grinding metal. I dont remember the setup of the ram pad, but i think its just a warning tab, letting you know its time.
lol sorry, didnt c u changed pads...i second bearings then/.
