Rim sizes for 01 ram
Old Mar 18, 2007 | 12:51 AM
stags79's Avatar
stags79
Default Rim sizes for 01 ram
I'm planning to swap out my factory 16x7 rims for some 15x8 or 15x9 rims and bigger tires, I'm just not sure what bacspacing I need to get before I make the swap. I'm pretty sure the factory rims are 4.5" backspacing. Can i use a rim with a little less back spacing in a wider size to keep a larger tire from rubbing when the wheel is turned to lock. I am currently running 255/85r16 tires with no lift and they work fine. I am planning to change to a 35x12.5x15 with a 2" leveling kit. I test fitted with a 315x75xr16 on a friends rims and they worked pretty well, just a little rub at full lock, and with the suspension flexed all the way. any help would be great. Thanks
Old Mar 19, 2007 | 01:17 AM
spaz_22's Avatar
spaz_22
Default RE: Rim sizes for 01 ram
what year is your ram? i have heard of people having problems with15 inch rims not fitting and hitting the calipers on i believe 98 and up rams becuase of the dual calipers....i heard you can grind the caliper to fit....
Old Mar 19, 2007 | 04:20 AM
stags79's Avatar
stags79
its a 2001 quad cab with the long bed. I have heard that I will need to grind the calipers to make the swap work, I came to terms with that a while ago. I was actually thinking about swapping to an aftermarket caliper with a lower profile, or maybe swaping in a set of calipers from a pre 98 ram.
Old Mar 19, 2007 | 01:40 PM
clint84's Avatar
clint84
you said you put a set of 315/75r16 on your truck and it just rubbed at lock and full flex? do you have the offroad package or do you have just a plain jane 4x4? i have an '01 too and want the biggest tire for the smallest lift.
Old Mar 19, 2007 | 02:22 PM
stags79's Avatar
stags79
It is just a pretty standard 01 1500 quad cab. I tried the 315/75r16 last summer and they fit pretty well, but they look like they will definitly will need ateast a 2" lift in the front to keep em from rubbing. for the cost of any decent tire in that size its probably cheaper to downsize to a 15" rim, thats why I started this thread.
Old Mar 19, 2007 | 07:28 PM
20dodgeram01's Avatar
20dodgeram01
i have 15x10's on my 01 ram.. sticks out a good 2inches.. took 6 inches of lift to clear 35's though when the whels stick out so far
Old Mar 19, 2007 | 09:54 PM
stags79's Avatar
stags79
20dodgeram01, what is the back spacing on the rims you have on right now? I have no problem going to a 6" kit if I need to, but I think that I am going to try a smaller lift first to see what will work the best. I still drive this truck everyday, I just need it to be big enough to be able to get back to camp, 33" are just not enought when its wet.
Old Mar 19, 2007 | 10:14 PM
20dodgeram01
3 5/8's backspacing.. they are eagle alloy 186 series 15x10's... 1 tried with just a 3 inch suspension lift and it rubbed the hell out of the body.. so i need to intall a 3 inch body lift on top of that to clear it
Old Mar 19, 2007 | 11:11 PM
stags79's Avatar
stags79
Thanks for the info, that helps a lot. I'm planning to get rims and tires this spring. the lift isn't really an issue, I just need to get the parts.
Old Mar 22, 2007 | 11:20 PM
redrocket2001's Avatar
redrocket2001
when i tried to get 15x8 on my 01 ram they said that you cant do it but i dunno something about the spacing and you cant go any smaller but i u can get 15's ima be mad cause that would have saved me so much money
so can you get 15's on 01s and up?
