gauges
Old Mar 19, 2007 | 02:03 PM
frede's Avatar
frede
Default gauges
hey guys does the volt gauge read off the battery or what the alternator is putting out.[/align]thanks fred[/align]
Old Mar 19, 2007 | 03:54 PM
DieselDemon's Avatar
DieselDemon
Default RE: gauges
The volt gauge reads the voltage in the electrical system.
If the truck is NOT running, you will be reading battery voltage. If the truck is running and the charging system is working properly, you will be reading the alternator's output voltage.
Good luck with your ride.
Old Mar 20, 2007 | 10:20 AM
frede's Avatar
frede
Default RE: gauges
thanks diesel, thats what i was thinking just wanted to make sure, fred
Old Mar 20, 2007 | 05:19 PM
farva's Avatar
farva
Default RE: gauges
actually the voltmeter just reads the amount of charge the battery has. When the truck is not running it show the amount of charge the battery has. When the truck is running it is showing the amount charge has when the alternator is giving the battery, remember the alternator not only powers all accessories but also charges the battery, so while you are driving the voltmeter will have a charge since it is being charged. Hope this helps you and you have a better understanding of your gauges.
