TMS Bill & HankL
Old Mar 21, 2007 | 10:51 PM
mcss8541's Avatar
mcss8541
Default TMS Bill & HankL
Hey guys I sent yall a message for help so check you in box, thanks!My 98 Ram 1500 has suddenly started to have starting issues. Normally when I start it up she fires right up; however the last 2 days it takes a long cranking cycle then she starts. When she starts she fires right up it's just now it's taking longer. I've been told that it could be a bleed off from the fuel pressure regulator, fuel pump might be going bad, spark plugs, etc. I have the 5.9L V-8 fuel injection and it's a 4 wheel drive truck. Thanks!
Old Mar 21, 2007 | 11:37 PM
TMS Bill's Avatar
TMS Bill
Default RE: TMS Bill & HankL
I'm thinking this one over and the more I think about it ... the more I think your throttle body and IAC need a visit from the carb cleaner fairy.
Then pull your plugs and check the gap.
Old Mar 21, 2007 | 11:47 PM
Cereal Killer's Avatar
Cereal Killer
Mine does the same thing, soif you figure it out lemme know
Old Mar 22, 2007 | 12:09 AM
mcss8541's Avatar
mcss8541
I know where the IAC valve is located on the 4.6L Ford engines but not on the 5.9L Dodges.....any suggestions? Also I started adding some Lucas fuel additive which has given me 15 more overall miles, but I've used that stuff for years along with Marvel Mystery Oil and I have had no problems. What are the symptoms of a fuel pump going bad?
Old Mar 22, 2007 | 12:15 AM
TMS Bill's Avatar
TMS Bill
The IAC is located on the back of the TB. Good write-up on cleaning and /or replacing here: https://dodgeforum.com/m_697481/tm.htm
I recommend cleaning first.
EDIT: Oh ... and a fuel pump usually doesn't slowly go bad ... it just quits ... as will your truck. It just won't start. Sometimes they're intermittent ... will start some days and not others ... but they don't consistently cause slow starts.
Old Mar 22, 2007 | 12:22 AM
mcss8541's Avatar
mcss8541
Thanks Wild Bill as usual you were a big help.
Old Mar 22, 2007 | 01:13 AM
Dallas192's Avatar
Dallas192
I had the same problem on my 97 dakota, it was the fuel pressure regulator. wasn't holding the prime..........Dallas
Old Mar 22, 2007 | 01:18 AM
mcss8541's Avatar
mcss8541
My best friend said the same thing he's a service manager at alarge Dodge dealership and that was the first thing he said. Where is the regulator located on the 5.9L?
Old Mar 22, 2007 | 01:25 AM
TMS Bill's Avatar
TMS Bill
Sits on top of the fuel pump.
Try the cheap and easy stuff first ... THEN start spending money and busting knuckles.
Old Mar 22, 2007 | 01:45 AM
mcss8541's Avatar
mcss8541
Roger That!
