oil pressure -roll the dice?
Old Mar 26, 2007 | 01:25 AM
fitpays's Avatar
fitpays
Default oil pressure -roll the dice?
hey guys. i did a search on here and thought i would post to see what you guys think in this instance. i have had my oil light flashing intermittently and my pressure dropping (according to the guage). anyway, i bought a new sending unit to try to rule that out. it proved to be more ag than it was worth. my oil was about a quart over-filled and i drained it to the proper level. i took it for a test drive and had no oil related lights/problems. i am hoping it was just over filled. after doing the search on here, i discovered it is very rare that the oil pump would go bad. so i guess my question is this -if the oil pump is bad, wouldnt it drop pressure all the time rather than just once in a while? it seems to be more symptomatic of an electrical issue than a mechanical issue. mechanical stuff is generally broke or not broke. very seldom in between. what do you guys think?
Old Mar 26, 2007 | 12:38 PM
2001mustang_gt's Avatar
2001mustang_gt
Default RE: oil pressure -roll the dice?
i have the same kind of problem..that i just posted about...mine only flashes when hot and idling in reverse or drive..is yours kinda the same issue..and my pressure does not drop
Old Mar 27, 2007 | 02:23 PM
fitpays's Avatar
fitpays
check your oil level. if it is low it will do it -and if it is high, it will do it. i drained my oil down to the appropriate level and have not had an incident yet. i am taking it on a longer test drive today and hopefully it is problem solved. i plan to take a 4 hour trip with it on thursday and i'm keeping my fingers crossed. i bought a sending unit but you have to have a special tool and be harry houdini to get to the damn thing. according to my research on here -99% of the time, these problems are electrical. this really makes sense, because if the pump were bad, i would think that it would act up ALL the time. mine does it intermittently. the only thing i can think that could be really bad is the screen might be getting clogged. i will know more after driving it today. i will probably put 60 miles or so on it today.
Old Mar 28, 2007 | 06:04 PM
fitpays's Avatar
fitpays
test drive yesterday no good! light came on and guage flopped to below zero in traffic at a light. i deliberately let it flounder below zero until the traffic light changed. no noise whatsoever! i think it is definately the sending unit now! how long do you guys think an engine could run with zero oil pressure on a warm day before hearing some kind of lifter noise or something???????? i think i'm good. guess i will find out for sure when i go on this long trip this weekend.
Old Mar 31, 2007 | 03:31 PM
94ram15004x4's Avatar
94ram15004x4
i had a similar problem, i put an aftermarket gauge in and it was ok, it must be in the wiring or the dash. but now i am having low oil pressure all the time 5-10 psi. i just replaced the oil pump, which helped but still drops to around 8 psi at 1500 rpm... i think i need bearings. but with your problem i would hooking an aftermarked gauge on it to see if its the sender unit, eletrical, or the oil pump. that will tell ya if the gauge is bad or not.
