CE 43** UPDATE
Old Mar 26, 2007 | 07:51 PM
Ram1500Dodge's Avatar
Ram1500Dodge
Default CE 43** UPDATE
check engine light 43** Peak primary circuit current not acheived with the maximum dwell time.
**These codes light up the CHECK ENGINE light on the instrument panel during engine operation once the trouble code has been recorded.
what the crap does that mean? trucks running fine, no problems what so ever.
Old Mar 26, 2007 | 10:44 PM
TMS Bill's Avatar
TMS Bill
Default RE: CE 43**
Sounds like your coil might be on it's way out.
Old Mar 26, 2007 | 11:58 PM
Gary-L's Avatar
Gary-L
Veteran: Navy
Default RE: CE 43**
ORIGINAL: TMS Bill
Agreed. Once that bad boy goes, you aren't going anywhere.
Old Mar 27, 2007 | 01:14 AM
Ram1500Dodge
Default RE: CE 43**
arethere any symptoms of this? how much does a coil usually run?
Old Mar 27, 2007 | 09:29 PM
Ram1500Dodge
Default RE: CE 43**
aight well i replaced the coil. went ahead did the plugs, wires, cap, and rotor then i reset the CE light...i'll give it a couple days and see what happens, hopefully that will solve the problems.
thanks fellas
Old Apr 1, 2007 | 03:48 AM
Ram1500Dodge
Default RE: CE 43**
so i replaced the coil and did a tune up...check engine light came on again today, same code. any ideas?
