things u find by going under the truck
Old Mar 28, 2007 | 03:38 AM
bigblueram's Avatar
bigblueram
Default things u find by going under the truck
Wow what a week for me. I decided to go under the truck to change the fluid of the front diff. I went looking around for other stuff. i found i needed to
tighten all bolts of the suspension and steering
replace the end links
clean the vacumm motor
replace broken u joint on front drive shaft(that baby was just magically hanging in there
transmission mount missing screws that go up to transsmision plate?
Transfer case oil very old had to change
regreased all joints
steering stabalizer was loose
Good thing the truck is lifted so i moved around freely looking at everything. I recomend everyone, when u got the time take a peak under there.
I dont really use the dodge its just used for off roading so i guess thats why i hadnt seen so many things wrong with it.
but well it seems that i have fixed pretty much what was needed and is up to date.
[IMG]local://upfiles/29694/3EA8AFB964024EF98416B9476A93355A.jpg[/IMG]
Old Mar 28, 2007 | 04:07 AM
Sinister's Avatar
Sinister
Default RE: things u find by going under the truck
your thumbnail has an error so i reuploaded it for you
