Timing chain install done
Old Oct 12, 2007 | 02:02 PM
IndyRamMan's Avatar
IndyRamMan
Default Timing chain install done
Incase anyone was wondering how it is after the timing chain install here it is. The throttle responce is instant, there is absolutely no hesitation anymore, but unfortunately I wasnt quite thinking and I installed 4* advanced rather than 4* retard, so I lost a bit of torque and hp, rather than hopefully gaining some. The water pump was leaking again today so I have to tear it down again, and Im going to change it to retard today while Im back in there. It should be better once I get that on right.
Old Oct 12, 2007 | 09:02 PM
aim4squirrels's Avatar
aim4squirrels
Default RE: Timing chain install done
Hey Indy,you wanna do awrite upor at least elaborate on what confused you from the Pavement Sucks article? You took a lot of pictures while you were in there. I'll probably need to do this over Winter Break.
Old Oct 12, 2007 | 10:25 PM
steve05ram360's Avatar
steve05ram360
you should do a writeup if you have enough pics & are willing to. nothing better than 1st hand experience in the forums here.
Old Oct 13, 2007 | 12:04 AM
IndyRamMan's Avatar
IndyRamMan
Ill do a write up for sure, prolly sunday or tues. The thing that confused me about the pavementsucks.com article was my dumb self. I wasnt looking at things properly, but after the first time, I tore it down and put it together really quick no problems.
btw. I set it at 4* retard and it is insane now...instant throttle responce, and the sob pulls like a raped ape. As far as bang for the buck seat of the pants satisfaction, this is by far my favorite mod. (I do have a check engine light for: Manufacture's Ignition system or Misfire. Anyone know why that could be? Think that would be learned by the pcm eventually?
Old Oct 13, 2007 | 03:27 AM
shott8283's Avatar
shott8283
since its mechanically retarded now instead of a electronic retard ( IE: programer.. ) u might went and done' pissed off the CPS
thad be me'first geuss
Old Oct 13, 2007 | 08:05 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: shott8283
what is the cps? I figgured i pissed off a sensor.
Edit: oh, the cam position sensor, or crank position sensor. But would that throw a code for ignition, or misfire?
Old Oct 13, 2007 | 08:58 AM
dhvaughan's Avatar
dhvaughan
congrats. ain't it great to learn something new.
Old Oct 13, 2007 | 10:40 AM
aim4squirrels
ORIGINAL: shott8283
but then wouldn't the same thing happen if you mod the crank sensor?
Old Oct 13, 2007 | 10:42 AM
IndyRamMan's Avatar
IndyRamMan
ORIGINAL: aim4squirrels
ORIGINAL: shott8283
im thinking if i do the crank sensor mod it may put the cel in check. any ideas?
ORIGINAL: dhvaughan
yeps!
Old Oct 13, 2007 | 10:50 AM
aim4squirrels
BTW Indy, What chain did you end up going with?
