Leveling kit, Major Major Problem
Old Feb 28, 2009 | 08:01 PM
Viper37's Avatar
Viper37
Default Leveling kit, Major Major Problem
So I've been hunting for the noise in my front end, and today I found it. I installed a 2 inch leveling kit a few weeks ago and on the rebound have had bump steer and a huge thunking noise when the truck comes back up.
The back of the spindle, right where the ball joint connects to it, is crashing into the top of the bump stop tower.
Holy Geometry batman! Regardless, I think I'm going to go with a pair of Doetsch 2 inch lift springs, or 3 inch lift spindles. I've gotta get on the horn with their folks and see what they have to say.
Anyone had this problem with leveling spacers before?
Anyways, I suppose I can grind off part of the tower where the bump stop sits to get that 1/2 inch of clearance I need, but I only see that as a bandaid, because the the upper arm would then crash fully into the top of the tower.
Idk, I think I see limit straps in my future.
Old Feb 28, 2009 | 09:02 PM
helms's Avatar
helms
i didnt realize your truck was 2wd, i was reading and racking my brain trying to figure out what you were talking about... then i looked at your sig. that is a wierd problem, but i have never looked very close at a 2wd front suspension, sorry
Old Feb 28, 2009 | 11:04 PM
TMS Bill's Avatar
TMS Bill
I didn't even know they made levelers for 4x2's.
Old Mar 2, 2009 | 03:02 AM
Viper37's Avatar
Viper37
I think I've figured a solution. I'm going to cut a tiny bit off of the edge of the bump stop seat, so my spindle will clear. Then, I will jack up the truck until I reach full extension (next interference point) measure, subtract about 1/2 inch, then make a little trip to ORW.
For now, I plan on correcting the problem with limit straps welded to the lower arm and to the frame.
In the long run, I plan on getting a new set of upper and lower arms, and using King Coilovers w/ air bump stops.
Long travel FTMFW.
Old Mar 2, 2009 | 09:08 AM
helms's Avatar
helms
limiting straps FTW, they're cool anyway
Old Mar 2, 2009 | 08:10 PM
Acapalic's Avatar
Acapalic
Viper if you could keep us posted about this. I would love to level lift my ram like yours. So if you come up with a solution for this post it here.
Old Mar 2, 2009 | 08:18 PM
Viper37's Avatar
Viper37
Will do. I bought some Beard 10 inch straps today, and am installing them on Wednesday.
Old Mar 3, 2009 | 01:56 AM
Viper37's Avatar
Viper37
I welded in a strap a little while ago. I'm going to have to move my bracket about a half inch higher. The compression in my spring is so great that It stretches the 3ply beard strap I have... lol
Pictures in a bit.
So, here's how it sits as of now. (When finalized the welds will be painted/coated)
and here is a picture that I took of a Soviet Submarine. Completely Unrelated.
