abs and brake light
Old Jul 4, 2009 | 08:08 PM
brokenram's Avatar
brokenram
Default abs and brake light
hi, thanks to the people that helped me with my u joint problem.
next problem is once in a while when i start my truck the abs and brake light come on. it will stay on until i shut it off and start it again. brakes are fine. doesnt always happen. maybe 30 percent of the time
any help is appreciated.
Old Jul 5, 2009 | 01:40 AM
Ram15002ndGen's Avatar
Ram15002ndGen
Speed sensor switch going bad. Its located on top of the rear differential. Pull it out and pop in a new one.
Last edited by Ram15002ndGen; Jul 6, 2009 at 12:00 AM. Reason: Duh, I typed too fast.
Old Jul 5, 2009 | 06:25 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Try disconnecting and reconnected the electrical plug on the speed sensor on top of the rear end a few times. It may be corroded.
Old Jul 5, 2009 | 09:12 AM
dhvaughan's Avatar
dhvaughan
Originally Posted by Ram15002ndGen
Neutral safety switch going bad. Its located on top of the rear differential. Pull it out and pop in a new one.
zman already said it, but just in case..
correction here - not neutral safety sw, thats in tranny.
also not the official speed sensor, thats in tranny.
its in the pumpkin but its usually called the anti-lock brake sensor. its rectangular shaped.
Old Jul 6, 2009 | 12:02 AM
Ram15002ndGen
Yea, duh, my brain said one thing and my hands did something else. Don't you just hate it when that happens?!
Old Jul 17, 2009 | 07:21 PM
dblj16380's Avatar
dblj16380
Yeah, once the ABS sensor goes officially bad then your speedometer won't register until your going 25+. It will sit on 0 until you get to 25 and jump right up and work fine. Then when you drop below 25 again it will fall to 0!
Old Jul 29, 2009 | 12:00 AM
FlytoFish's Avatar
FlytoFish
Eureka!!!! This just happened to mine! Thanks for the input, I'll have to get one for my pickup... Now, to figure out which one.
Old Jul 30, 2009 | 10:43 PM
dblj16380's Avatar
dblj16380
Like mentioned above it is the abs brake sensor in the rear diff. Be careful removing it as mine broke on the way out and I had to get in there with pliers and wiggle it all the way out. I also changed out the diff. fluid just to make sure no junk got in there when it broke!
