2500 coil springs in a 1500 4X4 ?
Old Sep 18, 2009 | 09:36 AM
stroken76's Avatar
stroken76
Default 2500 coil springs in a 1500 4X4 ?
Im thinking about putting a set of 2500 front coils in my 99 1500, How much more lift can I expect,is it going to ride like crap, Has anyone done this and what can i expect. Thanks in advance.
Old Sep 18, 2009 | 11:10 AM
Augiedoggy's Avatar
Augiedoggy
I believe it gives you 2-3 inches and it will ride like a 2500 not as soft ...I have 2500 springs in my 1500 and its a bit bouncy but I think my shocks are bad you will need add a leafs or blocks in the rear because the 2500 springs are wider than 1500 I believe. add a leafs give a stiff ride...mine do.
Old Sep 19, 2009 | 10:15 AM
olyelr's Avatar
olyelr
The V8 springs will net a little less lift than the V10 or Diesel springs (my truck gained just over 3" with the diesel springs, the V8 ones are usually around 2").
Ride stiffer? Oh yeah! But, get a nice shock like a Bilstein and it will ride just fine (but yes, MUCH stiffer than stock).
And like Augiedoggy stated, the rear springs don't just swap out because they are wider, so an add-a-leaf is the easiest fix. Don't add another block on top of the stocker.
Old Sep 22, 2009 | 09:44 AM
stroken76's Avatar
stroken76
Thanks guys for the response, Stroken
Old Sep 23, 2009 | 12:34 AM
TIMIDONE's Avatar
TIMIDONE
Default Front Coil Spring Diesel OR V10
Hey anyone know where I can get a front coil springs from a diesel or V10? I will then add a leaf in the back to lift the truck a little. I have been looking locally and can't an used one or online right now.
BTW will my stock shocks max out doing this little mod?
Old Sep 23, 2009 | 12:44 AM
dodge15004x45.9's Avatar
dodge15004x45.9
Junk yard for the coils. I have some off road edition coils if you want them. Buy new shocks.
Old Sep 23, 2009 | 12:46 AM
dodgeram07's Avatar
dodgeram07
http://rockauto.com/
Old Sep 23, 2009 | 01:12 AM
TIMIDONE's Avatar
TIMIDONE
yea I've been checking junkyards...just no luck! :| are the off road ones the same as the Diesel or V10 ones?
Old Sep 23, 2009 | 01:35 AM
dodge15004x45.9
I would bet there close. Rick how thick are those coils?
Old Sep 23, 2009 | 02:11 AM
TIMIDONE's Avatar
TIMIDONE
oh! I thought I read or asked or whatever most of this information...but it was so long ago!
Thanks!
