Exhaust long or short.
Old Jan 12, 2010 | 03:27 PM
dodge15004x45.9's Avatar
dodge15004x45.9
Question Exhaust long or short.
So after hitting that tree a few weeks ago I bent the y pipe. I had planned on putting short tube's on but now since I bent the y pipe I have an exhaust leak.
Since I already have the short tubes should I get a new y pipe and put the shorts on.
Or sell the shorts and get long tubes?
If I got the long tubes I would still have to buy a new cat due to pa emssions laws.
It looks like I would only be out 200 with cat and long tubes with y pipe.
I'm looking at getting it fixed by the spring before inspection. I'm leaning toward long tubes since I have to get a new y pipe might as well make is breath very good.
Old Jan 12, 2010 | 04:51 PM
lastrights's Avatar
lastrights
i say spend the money once, go with the longtubes
longtubes http://cgi.ebay.com/ebaymotors/Paces...Q5fAccessories
matching ypipe http://cgi.ebay.com/ebaymotors/94-01...Q5fAccessories
cat http://www.summitracing.com/parts/MPE-59959/
i would go with one of those aeroturbine mufflers 2525
i want to go with a h pipe but not sure if it would work or ot i never seen someone run one , or where to find it at .. indyram on ********* reccommmend this http://www.summitracing.com/parts/SUM-642030/
Old Jan 12, 2010 | 04:53 PM
dodge15004x45.9
But what about the o2's?
Old Jan 12, 2010 | 05:11 PM
lastrights's Avatar
lastrights
max, as you can see here the one 02 is the after cat but i dont have one , the pre cat o2 is on the passender side header but cant see in pic, but you can see there is enough wire for them both
Old Jan 12, 2010 | 06:41 PM
01Green5.9L's Avatar
01Green5.9L
I would sell the shorts and get the long tubes.
I just put shorties on mine only because the rest of my exhaust was in good shape,
if my y pipe and or cat where bad I would have gone long tube,
the long tube have better design than the shorts.
Old Jan 12, 2010 | 06:45 PM
lastrights's Avatar
lastrights
and the stock y-pipe is a bottle neck you would see a big diffrence if you went to a different y-pipe
Old Jan 12, 2010 | 06:52 PM
01Green5.9L
Ya I know what you are talking about, I just didn't want to go the extra $ right now,I don't like the way the drivers side shorty is made,I'm planning on the long and y when I need a new cat.
Old Jan 12, 2010 | 08:39 PM
360mag45's Avatar
360mag45
true duels in some states you need 2 cats 2 mufflers but you wouldn't if you are runing them into a y pipe you just have to move the cat
Old Jan 12, 2010 | 10:29 PM
lastrights's Avatar
lastrights
i dont see how you would run tru duels with a y pipe ??
Old Jan 13, 2010 | 12:03 AM
zje400ex's Avatar
zje400ex
how much for the shorties?
