cork
Old Feb 13, 2010 | 08:42 PM
dodgeram07's Avatar
dodgeram07
Default cork
any one using the Felpro / Intake Manifold Gasket that came with cork Gasket for the front and back of the intake man?
cause that wasin what i was looking for when i opened the box to day
maybe just rv the gasket and call it a day and dont worry about?
Old Feb 13, 2010 | 10:06 PM
cmckenna's Avatar
cmckenna
DON'T USE CORK...go with composite / steel seals. (they make a set P/N is the same with the additional suffix -1)
Those are the rubber ones and, somewhere in this forum, I have some really good instructions for how to create leak free gaskets. It was in an intake thread.
CM
Old Feb 13, 2010 | 10:16 PM
Miami_Son's Avatar
Miami_Son
^+1 Cork sucks! Harley used to use them on their early Evo engines. They dry out and shrink in no time and then it's leak city.
Old Feb 14, 2010 | 02:26 AM
dodgeram07's Avatar
dodgeram07
ya thats what i thought,,,, this what i got http://shop.advanceautoparts.com/web...S_842189133___
napa has the sum part number so does oreily ,,,autozone wed site is down right now
having a hard time finding what i want
cmckenna going try to find your gasket post i have a roll and gasket laying around here sum were
what about black silocone sealer for the front & rear ?
ok i found the gasket matiel but its like presses cardboad
Old Feb 14, 2010 | 06:00 AM
zman17's Avatar
zman17
Retired Moderator - RIP
Just call around and get the ms95392-1 set.
Old Feb 14, 2010 | 11:20 AM
cmckenna's Avatar
cmckenna
[QUOTE
[/QUOTE]
Recommendation: NOT to use that material. As stated earlier by me, get the same gasket set (same exact part No) with the -1 at the end of the P/N. The -1 is the suffix that is ammended to the P/N that calls out the composite / steel seals whereas, the NON suffix P/N calls out CORK.
I found it at O-Reily's / Kraigen. Order it from Summit, Jegs or Autoparts warehouse etc etc.
I know how difficult it is to find the CORRECT parts in a hurry via the net but, all you need is to go with Felrpo's -1 kit and some Gaskacinch and you'll be all set.
Ok, now, in regards to RTV being used for front and rear seals:
This is one of those things that some swear by while others state that the RTV breaks down with oil over time and, it's well known that RTV's are not really compatible with motor oils specifically.
However, depending on WHICH RTV is used, makes a HUGE difference in reliability of the seals.
PERMATEX makes some stuff called HI-TEMP BLACK which is oil resistant that "should" work.
I have used both methods to be honest and, the last time the intake was installed, I was in such a race to finish (in order to get out here for work) that I used RTV in place of the rubber end seals. Is it holding up? I don't know because I haven't checked the rear with a mirror to find that out.
However, I don't smell it so, I am going to guess that it is not weeping but, until I get a mirror on it and really look at it, I have no way of knowing.
I have always used the steel rubber inserts with tangs that insert into the seal holes along with a 1/4 inch bead of PERM HI TEMP BLK in all four corners PRIOR to placing the main gaskets in place. This way, the gasket sits IN the RTV so that it is completely enveloped not just ON TOP of the intake side of the gasket.
I have always used Gaskacinch for everything including water pumps etc and have never once had a failure- EVER. IT's that F-ing good. That product is flexible and so, it handles shear loads remarkably well thus, the gasket is not torn or ripped under prolonged use like some other materials.
I have NEVER had a leak using that method however, after speaking with HUGHES about what their customers use, most toss the end seals and run nothing but RTV. But, what they don't tell you is this:
That most of those guys use a STEEL insert - just like the end seals included in the -1 kits. These are perforated steel inserts that have tangs as well and, you envelope the entire steel insert with RTV.
CM
Old Feb 14, 2010 | 12:20 PM
dodgeram07's Avatar
dodgeram07
ok thanks alot guys for the help i found the correct part
just got back from oreailys they had it just it took her a little bit on time to find it in the computer,,, i went to autozone frist i about hit the guy up side of the head( said that part # didnt exass and took me cork is what it calls for and was talkin really lound,,,total d-bag
Old Feb 14, 2010 | 03:25 PM
zman17's Avatar
zman17
Dude! I have (almost) no idea what you just said.
Old Feb 14, 2010 | 03:42 PM
gipperkid's Avatar
gipperkid
So what is the proper way for installing the intake gasket set? Use permatex or no permatex with the side gaskets and front seals?
Old Feb 14, 2010 | 04:28 PM
Miami_Son's Avatar
Miami_Son
Lot of that in here lately. Damn young'uns. And southerners.
