I fixed my broken dash
Old Oct 4, 2012 | 10:49 PM
trip94's Avatar
trip94
Smile I fixed my broken dash
I recently purchased a 1996 Ram 1500. Needs a lot of work but cant spend a lot of money right now. I just started fixing some things that didn't require money. The PO didn't take very good care of it and was using it to go go mud bogging. It was even caked with mud under the hood. I cleaned as much as i could for now until i can get a pressure washer to finish. Anyway i started cleaning the inside which was in sad shape. After a lot of cleaning, it started looking pretty good except for the broken up dash. Pieces were all over inside the truck.I decided to see how much of it i could find and try to glue it back together. Found all but one piece. I figured if i could glue it together that i would have a base for a dash mat or something. I got it all patched up and it ended up being pretty solid. Instead of waiting to get a dash mat , I thought I'd try something that my daughter uses on floors and walls and other decorating items. I didn't plan on taking pics at first so the pics star after i was already into it a way. You will get the idea though and probably improve on it. I have no doubt that if i ever need to remove the dash that it will come out in one piece because its really solid now.
I'm going to try to put a link to my Photobucket album which will explain it more.Any one interested or any questions and I'll do the best i can to answer.
PS:
I couldn't use trip94 on Photobucket because it was used by someone else so i used trip96.
http://s1291.photobucket.com/albums/...%20Dash%20Fix/
Old Oct 5, 2012 | 05:43 AM
JSTMoto's Avatar
JSTMoto
Just a tip, but pressure washers are too strong for electrical connections and other components under the hood. I recommend garden hose pressure. At least cover up everything electrical and sensitive and get a tube of dielectric grease for any connectors you happen to hit.
Other than that, looks like an interesting dash repair approach for sure. And can't beat the price!
Post up some pics of everything assembled if you can.
Old Oct 5, 2012 | 07:27 AM
ZeroZero3's Avatar
ZeroZero3
Nice job!
Old Oct 5, 2012 | 07:38 AM
mantisman51's Avatar
mantisman51
What is that "stuff" on it? I have one crack on my 98, so far, and was going to use the cheapest rhynoliner bed coating I could find before it got any worse. But, I like the look of that.
Old Oct 5, 2012 | 07:42 AM
mantisman51
p.s. My son spilled several large mugs of coffee and soda on my carpet about 3 years ago and I used a 1 gallon sprayer with a mix of house carpet cleaning shampoo mixed with a tiny bit of dish detergent and a Shop Vac and after spraying and vacuuming with the shampoo, I rinsed with clean water and vacuumed it pretty close to dry and my carpet looks like new again and no musty or moldy smells either.
Old Oct 5, 2012 | 09:21 AM
redneck_ram's Avatar
redneck_ram
thats pretty damn sweet, nice job!! i would never have the patience to do something like that. kudos to you man!
Old Oct 5, 2012 | 09:48 AM
greanbeans's Avatar
greanbeans
What stuff did you use to fix that dash cause it looks good
Old Oct 5, 2012 | 09:51 AM
Hylander7's Avatar
Hylander7
That looks Great
Old Oct 5, 2012 | 10:31 AM
trip94's Avatar
trip94
Smile Heads up on Photobucket pics.
Just in case anyone overlooked it, There are 2 pages of pics of my dash on Photobucket. There are a total of 41 pics. Scroll down below each picture and there is a description of each picture of how its done.
Picture 35 shows a decent view of it completed. I hav'nt figured out how to post pictures from my pc yet.
Old Oct 5, 2012 | 11:20 AM
stewie01's Avatar
stewie01
When you are viewing your photo album in photobucket, simply put the mouse cursor over the picture and click img code it will auto copy it for you, then paste CTRL V to paste the link in a thread.
