Diagnostic Trouble Code List (HUGE thanks to Pyro for this!)
Old Mar 10, 2009 | 09:08 PM
  #21
Pyro's Avatar
Pyro
I Beat Tetris
P2000 - P2099
P2000 NOx Trap Eff Below Threshold Bank1
P2001 NOx Trap Eff Below Threshold Bank2
P2002 Particulate Trap Eff Below Threshold Bank1
P2003 Particulate Trap Eff Below Threshold Bank2
P2004 Intake Manif Runner Ctrl Stuck Open Bank1
P2005 Intake Manif Runner Ctrl Stuck Open Bank2
P2006 Intake Manif Runner Ctrl Stuck Closed Bank1
P2007 Intake Manif Runner Ctrl Stuck Closed Bank2
P2008 Intake Manif Runner Ctrl Circ/Open Bank1
P2009 Intake Manif Runner Ctrl Circ Low Bank1
P2010 Intake Manif Runner Ctrl Circ Hi Bank1
P2011 Intake Manif Runner Ctrl Circ/Open Bank2
P2012 Intake Manif Runner Ctrl Circ Low Bank2
P2013 Intake Manif Runner Ctrl Circ Hi Bank2
P2014 Intake Manif Runner Pos Sens/Switch Circ Bank1
P2015 Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank1
P2016 Intake Manif Runner Pos Sens/Switch Circ Low Bank1
P2017 Intake Manif Runner Pos Sens/Switch Circ Hi Bank1
P2018 Intake Manif Runner Pos Sens/Switch Circ Interm Bank1
P2019 Intake Manif Runner Pos Sens/Switch Circ Bank2
P2020 Intake Manif Runner Pos Sens/Switch Circ Range/Perf Bank2
P2021 Intake Manif Runner Pos Sens/Switch Circ Low Bank2
P2022 Intake Manif Runner Pos Sens/Switch Circ Hi Bank2
P2023 Intake Manif Runner Pos Sens/Switch Circ Interm Bank2
P2024 EVAP Emissions (EVAP) Fuel Vapor Temp Sens Circ
P2025 EVAP Fuel Vapor Temp Sens Perf
P2026 EVAP Fuel Vapor Temp Sens Circ Low Voltage
P2027 EVAP Fuel Vapor Temp Sens Circ Hi Voltage
P2028 EVAP Fuel Vapor Temp Sens Circ Interm
P2029 Fuel Fired Heater Disabled
P2030 Fuel Fired Heater Perf
P2031 Exhaust Gas Temp Sens Circ Bank1 Sens2
P2032 Exhaust Gas Temp Sens Circ Low Bank1 Sens2
P2033 Exhaust Gas Temp Sens Circ Hi Bank1 Sens2
P2034 Exhaust Gas Temp Sens Circ Bank2 Sens2
P2035 Exhaust Gas Temp Sens Circ Low Bank2 Sens2
P2036 Exhaust Gas Temp Sens Circ Hi Bank2 Sens2
P2037 Reductant Inj Air Press Sens Circ
P2038 Reductant Inj Air Press Sens Circ Range/Perf
P2039 Reductant Inj Air Press Sens Circ Low Input
P2040 Reductant Inj Air Press Sens Circ Hi Input
P2041 Reductant Inj Air Press Sens Circ Interm
P2042 Reductant Temp Sens Circ
P2043 Reductant Temp Sens Circ Range/Perf
P2044 Reductant Temp Sens Circ Low Input
P2045 Reductant Temp Sens Circ Hi Input
P2046 Reductant Temp Sens Circ Interm
P2047 Reductant Injector Circ/Open Bank1 Unit 1
P2048 Reductant Injector Circ Low Bank1 Unit 1
P2049 Reductant Injector Circ Hi Bank1 Unit 1
P2050 Reductant Injector Circ/Open Bank2 Unit 1
P2051 Reductant Injector Circ Low Bank2 Unit 1
P2052 Reductant Injector Circ Hi Bank2 Unit 1
P2053 Reductant Injector Circ/Open Bank1 Unit 2
P2054 Reductant Injector Circ Low Bank1 Unit 2
P2055 Reductant Injector Circ Hi Bank1 Unit 2
P2056 Reductant Injector Circ/Open Bank2 Unit 2
P2057 Reductant Injector Circ Low Bank2 Unit 2
P2058 Reductant Injector Circ Hi Bank2 Unit 2
P2059 Reductant Inj Air Pump Ctrl Circ/Open
P2060 Reductant Inj Air Pump Ctrl Circ Low
P2061 Reductant Inj Air Pump Ctrl Circ Hi
P2062 Reductant Supply Ctrl Circ/Open
P2063 Reductant Supply Ctrl Circ Low
P2064 Reductant Supply Ctrl Circ Hi
P2065 Fuel Level Sens B Circ
P2066 Fuel Level Sens B Perf
P2067 Fuel Level Sens B Circ Low
P2068 Fuel Level Sens B Circ Hi
P2069 Fuel Level Sens B Circ Interm
P2070 Intake Manif Tuning (IMT) Valve Stuck Open
P2071 IMT Valve Stuck Closed
P2075 IMT Valve Pos Sens/Switch Circ
P2076 IMT Valve Pos Sens/Switch Circ Range/Perf
P2077 IMT Valve Pos Sens/Switch Circ Low
P2078 IMT Valve Pos Sens/Switch Circ Hi
P2079 IMT Valve Pos Sens/Switch Circ Interm
P2080 Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens1
P2081 Exhaust Gas Temp Sens Circ Interm Bank1 Sens1
P2082 Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens1
P2083 Exhaust Gas Temp Sens Circ Interm Bank2 Sens1
P2084 Exhaust Gas Temp Sens Circ Range/Perf Bank1 Sens2
P2085 Exhaust Gas Temp Sens Circ Interm Bank1 Sens2
P2086 Exhaust Gas Temp Sens Circ Range/Perf Bank2 Sens2
P2087 Exhaust Gas Temp Sens Circ Interm Bank2 Sens2
P2088 A Camshaft Pos Actuator Ctrl Circ Low Bank1
P2089 A Camshaft Pos Actuator Ctrl Circ Hi Bank1
P2090 B Camshaft Pos Actuator Ctrl Circ Low Bank1 c)
P2091 B Camshaft Pos Actuator Ctrl Circ Hi Bank1 c)
P2092 A Camshaft Pos Actuator Ctrl Circ Low Bank2
P2093 A Camshaft Pos Actuator Ctrl Circ Hi Bank2
P2094 B Camshaft Pos Actuator Ctrl Circ Low Bank2 c)
P2095 B Camshaft Pos Actuator Ctrl Circ Hi Bank2 c)
P2096 Post Catalyst Fuel Trim Sys Too Lean Bank1
P2097 Post Catalyst Fuel Trim Sys Too Rich Bank1
P2098 Post Catalyst Fuel Trim Sys Too Lean Bank2
P2099 Post Catalyst Fuel Trim Sys Too Rich Bank2
Old Mar 10, 2009 | 09:10 PM
  #22
Pyro's Avatar
Pyro
I Beat Tetris
P2100 - P2199
P2100 Throttle Actuator Ctrl Motor Circ/Open
P2101 Throttle Actuator Ctrl Motor Circ Range/Perf
P2102 Throttle Actuator Ctrl Motor Circ Low
P2103 Throttle Actuator Ctrl Motor Circ Hi
P2104 Throttle Actuator Ctrl Sys-Forced Idle
P2105 Throttle Actuator Ctrl Sys-Forced Engine Shutdown
P2106 Throttle Actuator Ctrl Sys-Forced Limited Power
P2107 Throttle Actuator Ctrl Mod Processor
P2108 Throttle Actuator Ctrl Mod Perf
P2109 Throttle/Pedal Pos Sens A Minimum Stop Perf
P2110 Throttle Actuator Ctrl Sys-Forced Limited RPM
P2111 Throttle Actuator Ctrl Sys-Stuck Open
P2112 Throttle Actuator Ctrl Sys-Stuck Closed
P2113 Throttle/Pedal Pos Sens B Minimum Stop Perf
P2114 Throttle/Pedal Pos Sens C Minimum Stop Perf
P2115 Throttle/Pedal Pos Sens D Minimum Stop Perf
P2116 Throttle/Pedal Pos Sens E Minimum Stop Perf
P2117 Throttle/Pedal Pos Sens F Minimum Stop Perf
P2118 Throttle Actuator Ctrl Motor Current Range/Perf
P2119 Throttle Actuator Ctrl Throttle Body Range/Perf
P2120 Throttle/Pedal Pos Sens/Switch D Circ
P2121 Throttle/Pedal Pos Sens/Switch D Circ Range/Perf
P2122 Throttle/Pedal Pos Sens/Switch D Circ Low Input
P2123 Pedal Pos Sens1 Hi
P2124 Throttle/Pedal Pos Sens/Switch D Circ Interm
P2125 Throttle/Pedal Pos Sens/Switch E Circ
P2126 Throttle/Pedal Pos Sens/Switch E Circ Range/Perf
P2127 Pedal Pos Validation Switch 2 Low
P2128 Pedal Pos Validation Switch 2 Hi
P2129 Throttle/Pedal Pos Sens/Switch E Circ Interm
P2130 Throttle/Pedal Pos Sens/Switch F Circ
P2131 Throttle/Pedal Pos Sens/Switch F Circ Range Perf
P2132 Throttle/Pedal Pos Sens/Switch F Circ Low Input
P2133 Throttle/Pedal Pos Sens/Switch F Circ Hi Input
P2134 Throttle/Pedal Pos Sens/Switch F Circ Interm
P2135 Throttle/Pedal Pos Sens/Switch A/B Voltage Correlation
P2136 Throttle/Pedal Pos Sens/Switch A/C Voltage Correlation
P2137 Throttle/Pedal Pos Sens/Switch B/C Voltage Correlation
P2138 Throttle/Pedal Pos Sens/Switch D/E Voltage Correlation
P2139 Throttle/Pedal Pos Sens/Switch D/F Voltage Correlation
P2140 Throttle/Pedal Pos Sens/Switch E/F Voltage Correlation
P2141 Exhaust Gas Recirculation Throttle Ctrl Circ Low
P2142 Exhaust Gas Recirculation Throttle Ctrl Circ Hi
P2143 Exhaust Gas Recirculation Vent Ctrl Circ/Open
P2144 Exhaust Gas Recirculation Vent Ctrl Circ Low
P2145 Exhaust Gas Recirculation Vent Ctrl Circ Hi
P2146 Fuel Injector Group 1 Supply Voltage Circ
P2147 Fuel Injector Group 1 Supply Voltage Low
P2148 Fuel Injector Group 1 Supply Voltage Hi
P2149 Fuel Injector Group 2 Supply Voltage Circ
P2150 Fuel Injector Group 2 Supply Voltage Low
P2151 Fuel Injector Group 2 Supply Voltage Hi
P2152 Fuel Injector Group C Supply Voltage Circ/Open
P2153 Fuel Injector Group C Supply Voltage Circ Low
P2154 Fuel Injector Group C Supply Voltage Circ Hi
P2155 Fuel Injector Group D Supply Voltage Circ/Open
P2156 Fuel Injector Group D Supply Voltage Circ Low
P2157 Fuel Injector Group D Supply Voltage Circ Hi
P2158 Vehicle Speed Sens B
P2159 Vehicle Speed Sens B Range/Perf
P2160 Vehicle Speed Sens B Circ Low
P2161 Vehicle Speed Sens B Interm/Erratic
P2162 Vehicle Speed Sens A / B Correlation
P2163 Throttle/Pedal Pos Sens A Maximum Stop Perf
P2164 Throttle/Pedal Pos Sens B Maximum Stop Perf
P2165 Throttle/Pedal Pos Sens C Maximum Stop Perf
P2166 Throttle/Pedal Pos Sens D Maximum Stop Perf
P2167 Throttle/Pedal Pos Sens E Maximum Stop Perf
P2168 Throttle/Pedal Pos Sens F Maximum Stop Perf
P2169 Exhaust Press Regulator Vent Solenoid Ctrl Circ/Open
P2170 Exhaust Press Regulator Vent Solenoid Ctrl Circ Low
P2171 Exhaust Press Regulator Vent Solenoid Ctrl Circ Hi
P2172 Throttle Actuator Ctrl Sys-Sudden Hi Airflow Detected
P2173 Throttle Actuator Ctrl Sys-Hi Airflow Detected
P2174 Throttle Actuator Ctrl Sys-Sudden Low Airflow Detected
P2175 Throttle Actuator Ctrl Sys-Low Airflow Detected
P2176 Throttle Actuator Ctrl Sys-Idle Pos Not Learned
P2177 Sys Too Lean Off Idle Bank1
P2178 Sys Too Rich Off Idle Bank1
P2179 Sys Too Lean Off Idle Bank2
P2180 Sys Too Rich Off Idle Bank2
P2181 Cooling Sys Perf
P2182 Engine Coolant Temp Sens2 Circ
P2183 Engine Coolant Temp Sens2 Circ Range/Perf
P2184 Engine Coolant Temp Sens2 Circ Low
P2185 Engine Coolant Temp Sens2 Circ Hi
P2186 Engine Coolant Temp Sens2 Circ Interm/Erratic
P2187 Sys Too Lean at Idle Bank1
P2188 Sys Too Rich at Idle Bank1
P2189 Sys Too Lean at Idle Bank2
P2190 Sys Too Rich at Idle Bank2
P2191 Sys Too Lean at Hier Load Bank1
P2192 Sys Too Rich at Hier Load Bank1
P2193 Sys Too Lean at Hier Load Bank2
P2194 Sys Too Rich at Hier Load Bank2
P2195 O2 Sens Signal Stuck Lean Bank1 Sens1
P2196 O2 Sens Signal Stuck Rich Bank1 Sens1
P2197 O2 Sens Signal Stuck Lean Bank2 Sens1
P2198 O2 Sens Signal Stuck Rich Bank2 Sens1
P2199 Intake Air Temp Sens1 / 2 Correlation
Old Mar 10, 2009 | 09:16 PM
  #23
Pyro's Avatar
Pyro
I Beat Tetris
P2200 - P2299
P2200 NOx Sens Circ Bank1
P2201 NOx Sens Circ Range/Perf Bank1
P2202 NOx Sens Circ Low Input Bank1
P2203 NOx Sens Circ Hi Input Bank1
P2204 NOx Sens Circ Interm Input Bank1
P2205 NOx Sens Heater Ctrl Circ/Open Bank1
P2206 NOx Sens Heater Ctrl Circ Low Bank1
P2207 NOx Sens Heater Ctrl Circ Hi Bank1
P2208 NOx Sens Heater Sense Circ Bank1
P2209 NOx Sens Heater Sense Circ Range/Perf Bank1
P2210 NOx Sens Heater Sense Circ Low Input Bank1
P2211 NOx Sens Heater Sense Circ Hi Input Bank1
P2212 NOx Sens Heater Sense Circ Interm Bank1
P2213 NOx Sens Circ Bank2
P2214 NOx Sens Circ Range/Perf Bank2
P2215 NOx Sens Circ Low Input Bank2
P2216 NOx Sens Circ Hi Input Bank2
P2217 NOx Sens Circ Interm Input Bank2
P2218 NOx Sens Heater Ctrl Circ/Open Bank2
P2219 NOx Sens Heater Ctrl Circ Low Bank2
P2220 NOx Sens Heater Ctrl Circ Hi Bank2
P2221 NOx Sens Heater Sense Circ Bank2
P2222 NOx Sens Heater Sense Circ Range/Perf Bank2
P2223 NOx Sens Heater Sense Circ Low Bank2
P2224 NOx Sens Heater Sense Circ Hi Bank2
P2225 NOx Sens Heater Sense Circ Interm Bank2
P2226 Barometric Press Circ
P2227 Barometric Press Circ Range/Perf
P2228 Barometric Press Circ Low
P2229 Barometric Press Circ Hi
P2230 Barometric Press Circ Interm
P2231 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens1
P2232 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens2
P2233 O2 Sens Signal Circ Shorted to Heater Circ Bank1 Sens3
P2234 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens1
P2235 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens2
P2236 O2 Sens Signal Circ Shorted to Heater Circ Bank2 Sens3
P2237 O2 Sens Positive Current Ctrl Circ/Open Bank1 Sens1
P2238 O2 Sens Positive Current Ctrl Circ Low Bank1 Sens1
P2239 O2 Sens Positive Current Ctrl Circ Hi Bank1 Sens1
P2240 O2 Sens Positive Current Ctrl Circ/Open Bank2 Sens1
P2241 O2 Sens Positive Current Ctrl Circ Low Bank2 Sens1
P2242 O2 Sens Positive Current Ctrl Circ Hi Bank2 Sens1
P2243 O2 Sens Ref Voltage Circ/Open Bank1 Sens1
P2244 O2 Sens Ref Voltage Perf Bank1 Sens1
P2245 O2 Sens Ref Voltage Circ Low Bank1 Sens1
P2246 O2 Sens Ref Voltage Circ Hi Bank1 Sens1
P2247 O2 Sens Ref Voltage Circ/Open Bank2 Sens1
P2248 O2 Sens Ref Voltage Perf Bank2 Sens1
P2249 O2 Sens Ref Voltage Circ Low Bank2 Sens1
P2250 O2 Sens Ref Voltage Circ Hi Bank2 Sens1
P2251 O2 Sens Negative Current Ctrl Circ/Open Bank1 Sens1
P2252 O2 Sens Negative Current Ctrl Circ Low Bank1 Sens1
P2253 O2 Sens Negative Current Ctrl Circ Hi Bank1 Sens1
P2254 O2 Sens Negative Current Ctrl Circ/Open Bank2 Sens1
P2255 O2 Sens Negative Current Ctrl Circ Low Bank2 Sens1
P2256 O2 Sens Negative Current Ctrl Circ Hi Bank2 Sens1
P2257 Sec Air Inj Sys Ctrl A Circ Low
P2258 Sec Air Inj Sys Ctrl A Circ Hi
P2259 Sec Air Inj Sys Ctrl B Circ Low
P2260 Sec Air Inj Sys Ctrl B Circ Hi
P2261 T/Super Charger Bypass Valve-Mechanical
P2262 Turbo Boost Press Not Detected-Mechanical
P2263 T/Super Charger Boost Sys Perf
P2264 Water in Fuel Sens Circ
P2265 Water in Fuel Sens Circ Range/Perf
P2266 Water in Fuel Sens Circ Low
P2267 Water in Fuel Sens Circ Hi
P2268 Water in Fuel Sens Circ Interm
P2269 Water in Fuel Condition
P2270 O2 Sens Signal Stuck Lean Bank1 Sens2
P2271 O2 Sens Signal Stuck Rich Bank1 Sens2
P2272 O2 Sens Signal Stuck Lean Bank2 Sens2
P2273 O2 Sens Signal Stuck Rich Bank2 Sens2
P2274 O2 Sens Signal Stuck Lean Bank1 Sens3
P2275 O2 Sens Signal Stuck Rich Bank1 Sens3
P2276 O2 Sens Signal Stuck Lean Bank2 Sens3
P2277 O2 Sens Signal Stuck Rich Bank2 Sens3
P2278 O2 Sens Signals Swapped Bank1 Sens3 / Bank2 Sens3
P2279 Intake Air Sys Leak
P2280 Air Flow Restriction / Air Leak Between Air Filter and MAF
P2281 Air Leak Between MAF and Throttle Body
P2282 Air Leak Between Throttle Body and Intake Valves
P2283 Injector Ctrl Press Sens Circ
P2284 Injector Ctrl Press Sens Circ Range/Perf
P2285 Injector Ctrl Press Sens Circ Low
P2286 Injector Ctrl Press Sens Circ Hi
P2287 Injector Ctrl Press Sens Circ Interm
P2288 Injector Ctrl Press Too Hi
P2289 Injector Ctrl Press Too Hi-Engine Off
P2290 Injector Ctrl Press Too Low
P2291 Injector Ctrl Press Too Low-Engine Cranking
P2292 Injector Ctrl Press Erratic
P2293 Fuel Press Regulator 2 Perf
P2294 Fuel Press Regulator 2 Ctrl Circ
P2295 Fuel Press Regulator 2 Ctrl Circ Low
P2296 Fuel Press Regulator 2 Ctrl Circ Hi
P2297 O2 Sens Out of Range During Deceleration Bank1 Sens1
P2298 O2 Sens Out of Range During Deceleration Bank2 Sens1
P2299 Brake Pedal Pos / Accelerator Pedal Pos Incompatible
Old Mar 10, 2009 | 09:17 PM
  #24
Pyro's Avatar
Pyro
I Beat Tetris
P2300 - P2399
P2300 Ignition Coil A Primary Ctrl Circ Low
P2301 Ignition Coil A Primary Ctrl Circ Hi
P2302 Ignition Coil A Sec Circ
P2303 Ignition Coil B Primary Ctrl Circ Low
P2304 Ignition Coil B Primary Ctrl Circ Hi
P2305 Ignition Coil B Sec Circ
P2306 Ignition Coil C Primary Ctrl Circ Low
P2307 Ignition Coil C Primary Ctrl Circ Hi
P2308 Ignition Coil C Sec Circ
P2309 Ignition Coil D Primary Ctrl Circ Low
P2310 Ignition Coil D Primary Ctrl Circ Hi
P2311 Ignition Coil D Sec Circ
P2312 Ignition Coil E Primary Ctrl Circ Low
P2313 Ignition Coil E Primary Ctrl Circ Hi
P2314 Ignition Coil E Sec Circ
P2315 Ignition Coil F Primary Ctrl Circ Low
P2316 Ignition Coil F Primary Ctrl Circ Hi
P2317 Ignition Coil F Sec Circ
P2318 Ignition Coil G Primary Ctrl Circ Low
P2319 Ignition Coil G Primary Ctrl Circ Hi
P2320 Ignition Coil G Sec Circ
P2321 Ignition Coil H Primary Ctrl Circ Low
P2322 Ignition Coil H Primary Ctrl Circ Hi
P2323 Ignition Coil H Sec Circ
P2324 Ignition Coil I Primary Ctrl Circ Low
P2325 Ignition Coil I Primary Ctrl Circ Hi
P2326 Ignition Coil I Sec Circ
P2327 Ignition Coil J Primary Ctrl Circ Low
P2328 Ignition Coil J Primary Ctrl Circ Hi
P2329 Ignition Coil J Sec Circ
P2330 Ignition Coil K Primary Ctrl Circ Low
P2331 Ignition Coil K Primary Ctrl Circ Hi
P2332 Ignition Coil K Sec Circ
P2333 Ignition Coil L Primary Ctrl Circ Low
P2334 Ignition Coil L Primary Ctrl Circ Hi
P2335 Ignition Coil L Sec Circ
P2336 Cylinder #1 Above Knock Threshold
P2337 Cylinder #2 Above Knock Threshold
P2338 Cylinder #3 Above Knock Threshold
P2339 Cylinder #4 Above Knock Threshold
P2340 Cylinder #5 Above Knock Threshold
P2341 Cylinder #6 Above Knock Threshold
P2342 Cylinder #7 Above Knock Threshold
P2343 Cylinder #8 Above Knock Threshold
P2344 Cylinder #9 Above Knock Threshold
P2345 Cylinder #10 Above Knock Threshold
P2346 Cylinder #11 Above Knock Threshold
P2347 Cylinder #12 Above Knock Threshold
Old Mar 10, 2009 | 09:20 PM
  #25
Pyro's Avatar
Pyro
I Beat Tetris
P2400 - P2499
P2400 EVAP Emission Sys Leak Detection Pump Ctrl Circ/Open
P2401 EVAP Emission Sys Leak Detection Pump Ctrl Circ Low
P2402 EVAP Emission Sys Leak Detection Pump Ctrl Circ Hi
P2403 EVAP Emission Sys Leak Detection Pump Sense Circ/Open
P2404 EVAP Emission Sys Leak Detection Pump Sense Circ Range/Perf
P2405 EVAP Emission Sys Leak Detection Pump Sense Circ Low
P2406 EVAP Emission Sys Leak Detection Pump Sense Circ Hi
P2407 EVAP Emission Sys Leak Detection Pump Sense Circ Interm/Erratic
P2408 Fuel Cap Sens/Switch Circ
P2409 Fuel Cap Sens/Switch Circ Range/Perf
P2410 Fuel Cap Sens/Switch Circ Low
P2411 Fuel Cap Sens/Switch Circ Hi
P2412 Fuel Cap Sens/Switch Circ Interm/Erratic
P2413 Exhaust Gas Recirculation Sys Perf
P2414 O2 Sens Exhaust Sample Error Bank1 Sens1
P2415 O2 Sens Exhaust Sample Error Bank2 Sens1
P2416 O2 Sens Signals Swapped Bank1 Sens2 / Bank1 Sens3
P2417 O2 Sens Signals Swapped Bank2 Sens2 / Bank2 Sens3
P2418 EVAP Emission Sys Switching Valve Ctrl Circ /Open
P2419 EVAP Emission Sys Switching Valve Ctrl Circ Low
P2420 EVAP Emission Sys Switching Valve Ctrl Circ Hi
P2421 EVAP Emission Sys Vent Valve Stuck Open
P2422 EVAP Emission Sys Vent Valve Stuck Closed
P2423 HC Adsorption Catalyst Eff Below Threshold Bank1
P2424 HC Adsorption Catalyst Eff Below Threshold Bank2
P2425 Exhaust Gas Recirculation Cooling Valve Ctrl Circ/Open
P2426 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Low
P2427 Exhaust Gas Recirculation Cooling Valve Ctrl Circ Hi
P2428 Exhaust Gas Temp Too Hi Bank1
P2429 Exhaust Gas Temp Too Hi Bank2
P2430 Sec Air Inj Sys Air Flow/Press Sens Circ Bank1
P2431 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank1
P2432 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank1
P2433 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank1
P2434 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank1
P2435 Sec Air Inj Sys Air Flow/Press Sens Circ Bank2
P2436 Sec Air Inj Sys Air Flow/Press Sens Circ Range/Perf Bank2
P2437 Sec Air Inj Sys Air Flow/Press Sens Circ Low Bank2
P2438 Sec Air Inj Sys Air Flow/Press Sens Circ Hi Bank2
P2439 Sec Air Inj Sys Air Flow/Press Sens Circ Erratic Bank2
P2440 Sec Air Inj Sys Switching Valve Stuck Open Bank1
P2441 Sec Air Inj Sys Switching Valve Stuck Closed Bank1
P2442 Sec Air Inj Sys Switching Valve Stuck Open Bank2
P2443 Sec Air Inj Sys Switching Valve Stuck Closed Bank2
P2444 Sec Air Inj Sys Pump Stuck On Bank1
P2445 Sec Air Inj Sys Pump Stuck Off Bank1
P2446 Sec Air Inj Sys Pump Stuck On Bank2
P2447 Sec Air Inj Sys Pump Stuck Off Bank2
Old Mar 10, 2009 | 09:22 PM
  #26
Pyro's Avatar
Pyro
I Beat Tetris
P2500 - P2599
P2500 Generator Lamp/L-Terminal Circ Low
P2501 Generator Lamp/L-Terminal Circ Hi
P2502 Charging Sys Output Voltage
P2503 Charging Sys Output Voltage Low
P2504 Charging Sys Output Voltage Hi
P2505 ECM/PCM Power Input Signal
P2506 ECM/PCM Power Input Signal Range/Perf
P2507 ECM/PCM Power Input Signal Low
P2508 ECM/PCM Power Input Signal Hi
P2509 CM/PCM Power Input Signal Interm
P2510 ECM/PCM Power Relay Sense Circ Range/Perf
P2511 ECM/PCM Power Relay Sense Circ Interm
P2512 Event Data Recorder Request Circ/ Open
P2513 Event Data Recorder Request Circ Low
P2514 Event Data Recorder Request Circ Hi
P2515 A/C Refrigerant Press Sens B Circ
P2516 A/C Refrigerant Press Sens B Circ Range/Perf
P2517 A/C Refrigerant Press Sens B Circ Low
P2518 A/C Refrigerant Press Sens B Circ Hi
P2519 A/C Request A Circ
P2520 A/C Request A Circ Low
P2521 A/C Request A Circ Hi
P2522 A/C Request B Circ
P2523 A/C Request B Circ Low
P2524 A/C Request B Circ Hi
P2525 Vacuum Reservoir Press Sens Circ
P2526 Vacuum Reservoir Press Sens Circ Range/Perf
P2527 Vacuum Reservoir Press Sens Circ Low
P2528 Vacuum Reservoir Press Sens Circ Hi
P2529 Vacuum Reservoir Press Sens Circ Interm
P2530 Ignition Switch Run Pos Circ
P2531 Ignition Switch Run Pos Circ Low
P2532 Ignition Switch Run Pos Circ Hi
P2533 Ignition Switch Run/Start Pos Circ
P2534 Ignition Switch Run/Start Pos Circ Low
P2535 Ignition Switch Run/Start Pos Circ Hi
P2536 Ignition Switch Accessory Pos Circ
P2537 Ignition Switch Accessory Pos Circ Low
P2538 Ignition Switch Accessory Pos Circ Hi
P2539 Low Press Fuel Sys Sens Circ
P2540 Low Press Fuel Sys Sens Circ Range/Perf
P2541 Low Press Fuel Sys Sens Circ Low
P2542 Low Press Fuel Sys Sens Circ Hi
P2543 Low Press Fuel Sys Sens Circ Interm
P2544 Torque Management Request Input Signal A
P2545 Torque Management Request Input Signal A Range/Perf
P2546 Torque Management Request Input Signal A Low
P2547 Torque Management Request Input Signal A Hi
P2548 Torque Management Request Input Signal B
P2549 Torque Management Request Input Signal B Range/Perf
P2550 Torque Management Request Input Signal B Low
P2551 Torque Management Request Input Signal B Hi
P2552 Throttle/Fuel Inhibit Circ
P2553 Throttle/Fuel Inhibit Circ Range/Perf
P2554 Throttle/Fuel Inhibit Circ Low
P2555 Throttle/Fuel Inhibit Circ Hi
P2556 Engine Coolant Level Sens/Switch Circ
P2557 Engine Coolant Level Sens/Switch Circ Range/Perf
P2558 Engine Coolant Level Sens/Switch Circ Low
P2559 Engine Coolant Level Sens/Switch Circ Hi
P2560 Engine Coolant Level Low
P2561 A/C Ctrl Mod Requested MIL Illumination
P2562 Turbocharger Boost Ctrl Pos Sens Circ
P2563 Turbocharger Boost Ctrl Pos Sens Circ Range/Perf
P2564 Turbocharger Boost Ctrl Pos Sens Circ Low
P2565 Turbocharger Boost Ctrl Pos Sens Circ Hi
P2566 Turbocharger Boost Ctrl Pos Sens Circ Interm
P2567 Direct Ozone Reduction Catalyst Temp Sens Circ
P2568 Direct Ozone Reduction Catalyst Temp Sens Circ Range/Perf
P2569 Direct Ozone Reduction Catalyst Temp Sens Circ Low
P2570 Direct Ozone Reduction Catalyst Temp Sens Circ Hi
P2571 Direct Ozone Reduction Catalyst Temp Sens Circ Interm/Erratic
P2572 Direct Ozone Reduction Catalyst Deterioration Sens Circ
P2573 Direct Ozone Reduction Catalyst Deterioration Sens Circ Range/Perf
P2574 Direct Ozone Reduction Catalyst Deterioration Sens Circ Low
P2575 Direct Ozone Reduction Catalyst Deterioration Sens Circ Hi
P2576 Direct Ozone Reduction Catalyst Deterioration Sens Circ Interm/Erratic
P2577 Direct Ozone Reduction Catalyst Eff Below Threshold
Old Mar 10, 2009 | 09:24 PM
  #27
Pyro's Avatar
Pyro
I Beat Tetris
P2600 - P2699
P2600 Coolant Pump Ctrl Circ/Open
P2601 Coolant Pump Ctrl Circ Range/Perf
P2602 Coolant Pump Ctrl Circ Low
P2603 Coolant Pump Ctrl Circ Hi
P2604 Intake Air Heater A Circ Range/Perf
P2605 Intake Air Heater A Circ/Open
P2606 Intake Air Heater B Circ Range/Perf
P2607 Intake Air Heater Relay 2 Low
P2608 Intake Air Heater Relay 2 Hi
P2609 Intake Air Heater Sys Perf
P2610 ECM/PCM Internal Engine Off Timer Perf
P2611 A/C Refrigerant Distribution Valve Ctrl Circ/Open
P2612 A/C Refrigerant Distribution Valve Ctrl Circ Low
P2613 A/C Refrigerant Distribution Valve Ctrl Circ Hi
P2614 Camshaft Pos Signal Output Circ/Open
P2615 Camshaft Pos Signal Output Circ Low
P2616 Camshaft Pos Signal Output Circ Hi
P2617 Crank Pos Signal Output Circ/Open
P2618 Crank Pos Signal Output Circ Low
P2619 Crank Pos Signal Output Circ Hi
P2620 Throttle Pos Output Circ/Open
P2621 Throttle Pos Output Circ Low
P2622 Throttle Pos Output Circ Hi
P2623 Injector Ctrl Press Regulator Circ/Open
P2624 Injector Ctrl Press Regulator Circ Low
P2625 Injector Ctrl Press Regulator Circ Hi
P2626 O2 Sens Pumping Current Trim Circ/Open Bank1 Sens1
P2627 O2 Sens Pumping Current Trim Circ Low Bank1 Sens1
P2628 O2 Sens Pumping Current Trim Circ Hi Bank1 Sens1
P2629 O2 Sens Pumping Current Trim Circ/Open Bank2 Sens1
P2630 O2 Sens Pumping Current Trim Circ Low Bank2 Sens1
P2631 O2 Sens Pumping Current Trim Circ Hi Bank2 Sens1
P2632 Fuel Pump B Ctrl Circ /Open
P2633 Fuel Pump B Ctrl Circ Low
P2634 Fuel Pump B Ctrl Circ Hi
P2635 Fuel Pump A Low Flow / Perf
P2636 Fuel Pump B Low Flow / Perf
P2637 Torque Management Feedback Signal A
P2638 Torque Management Feedback Signal A Range/Perf
P2639 Torque Management Feedback Signal A Low
P2640 Torque Management Feedback Signal A Hi
P2641 Torque Management Feedback Signal B
P2642 Torque Management Feedback Signal B Range/Perf
P2643 Torque Management Feedback Signal B Low
P2644 Torque Management Feedback Signal B Hi
P2645 A Rocker Arm Actuator Ctrl Circ/Open Bank1
P2646 A Rocker Arm Actuator Sys Perf or Stuck Off Bank1
P2647 A Rocker Arm Actuator Sys Stuck On Bank1
P2648 A Rocker Arm Actuator Ctrl Circ Low Bank1
P2649 A Rocker Arm Actuator Ctrl Circ Hi Bank1
P2650 B Rocker Arm Actuator Ctrl Circ/Open Bank1
P2651 B Rocker Arm Actuator Sys Perf or Stuck Off Bank1
P2652 B Rocker Arm Actuator Sys Stuck On Bank1
P2653 B Rocker Arm Actuator Ctrl Circ Low Bank1
P2654 B Rocker Arm Actuator Ctrl Circ Hi Bank1
P2655 A Rocker Arm Actuator Ctrl Circ/Open Bank2
P2656 A Rocker Arm Actuator Sys Perf or Stuck Off Bank2
P2657 A Rocker Arm Actuator Sys Stuck On Bank2
P2658 A Rocker Arm Actuator Ctrl Circ Low Bank2
P2659 A Rocker Arm Actuator Ctrl Circ Hi Bank2
P2660 B Rocker Arm Actuator Ctrl Circ/Open Bank2
P2661 B Rocker Arm Actuator Sys Perf or Stuck Off Bank2
P2662 B Rocker Arm Actuator Sys Stuck On Bank2
P2663 B Rocker Arm Actuator Ctrl Circ Low Bank2
P2664 B Rocker Arm Actuator Ctrl Circ Hi Bank2
P2665 Fuel Shutoff Valve B Ctrl Circ/Open
P2666 Fuel Shutoff Valve B Ctrl Circ Low
P2667 Fuel Shutoff Valve B Ctrl Circ Hi
P2668 Fuel Mode Indicator Lamp Ctrl Circ
P2669 Actuator Supply Voltage B Circ /Open
P2670 Actuator Supply Voltage B Circ Low
P2671 Actuator Supply Voltage B Circ Hi
Old Mar 10, 2009 | 09:29 PM
  #28
Pyro's Avatar
Pyro
I Beat Tetris
P2700 - P2799
P2700 Trans Friction Element A Apply Time Range/Perf
P2701 Trans Friction Element B Apply Time Range/Perf
P2702 Trans Friction Element C Apply Time Range/Perf
P2703 Trans Friction Element D Apply Time Range/Perf
P2704 Trans Friction Element E Apply Time Range/Perf
P2705 Trans Friction Element F Apply Time Range/Perf
P2706 Shift Solenoid F
P2707 Shift Solenoid F Perf or Stuck Off
P2708 Shift Solenoid F Stuck On
P2709 Shift Solenoid F Electrical
P2710 Shift Solenoid F Interm
P2711 Unexpected Mechanical Gear Disengagement
P2712 Hydraulic Power Unit Leakage
P2713 Press Ctrl Solenoid D
P2714 Press Ctrl Solenoid D Perf or Stuck Off
P2715 Press Ctrl Solenoid D Stuck On
P2716 Press Ctrl Solenoid D Electrical
P2717 Press Ctrl Solenoid D Interm
P2718 Press Ctrl Solenoid D Ctrl Circ / Open
P2719 Press Ctrl Solenoid D Ctrl Circ Range/Perf
P2720 Press Ctrl Solenoid D Ctrl Circ Low
P2721 Press Ctrl Solenoid D Ctrl Circ Hi
P2722 Press Ctrl Solenoid E
P2723 Press Ctrl Solenoid E Perf or Stuck Off
P2724 Press Ctrl Solenoid E Stuck On
P2725 Press Ctrl Solenoid E Electrical
P2726 Press Ctrl Solenoid E Interm
P2727 Press Ctrl Solenoid E Ctrl Circ / Open
P2728 Press Ctrl Solenoid E Ctrl Circ Range/Perf
P2729 Press Ctrl Solenoid E Ctrl Circ Low
P2730 Press Ctrl Solenoid E Ctrl Circ Hi
P2731 Press Ctrl Solenoid F
P2732 Press Ctrl Solenoid F Perf or Stuck Off
P2733 Press Ctrl Solenoid F Stuck On
P2734 Press Ctrl Solenoid F Electrical
P2735 Press Ctrl Solenoid F Interm
P2736 Press Ctrl Solenoid F Ctrl Circ/Open
P2737 Press Ctrl Solenoid F Ctrl Circ Range/Perf
P2738 Press Ctrl Solenoid F Ctrl Circ Low
P2739 Press Ctrl Solenoid F Ctrl Circ Hi
P2740 Trans Fluid Temp Sens B Circ
P2741 Trans Fluid Temp Sens B Circ Range Perf
P2742 Trans Fluid Temp Sens B Circ Low
P2743 Trans Fluid Temp Sens B Circ Hi
P2744 Trans Fluid Temp Sens B Circ Interm
P2745 Intermediate Shaft Speed Sens B Circ
P2746 Intermediate Shaft Speed Sens B Circ Range/Perf
P2747 Intermediate Shaft Speed Sens B Circ No Signal
P2748 Intermediate Shaft Speed Sens B Circ Interm
P2749 Intermediate Shaft Speed Sens C Circ
P2750 Intermediate Shaft Speed Sens C Circ Range/Perf
P2751 Intermediate Shaft Speed Sens C Circ No Signal
P2752 Intermediate Shaft Speed Sens C Circ Interm
P2753 Trans Fluid Cooler Ctrl Circ/Open
P2754 Trans Fluid Cooler Ctrl Circ Low
P2755 Trans Fluid Cooler Ctrl Circ Hi
P2756 Torque Conv Clutch Press Ctrl Solenoid
P2757 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Perf or Stuck Off
P2758 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Stuck On
P2759 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Electrical
P2760 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Interm
P2761 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ/Open
P2762 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Range/Perf
P2763 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Hi
P2764 Torque Conv Clutch Press Ctrl Solenoid Ctrl Circ Low
P2765 Input/Turbine Speed Sens B Circ
P2766 Input/Turbine Speed Sens B Circ Range/Perf
P2767 Input/Turbine Speed Sens B Circ No Signal
P2768 Input/Turbine Speed Sens B Circ Interm
P2769 Torque Conv Clutch Circ Low
P2770 Torque Conv Clutch Circ Hi
P2771 Four Wheel Drive (4WD) Low Switch Circ
P2772 Four Wheel Drive (4WD) Low Switch Circ Range/Perf
P2773 Four Wheel Drive (4WD) Low Switch Circ Low
P2774 Four Wheel Drive (4WD) Low Switch Circ Hi
P2775 Upshift Switch Circ Range/Perf
P2776 Upshift Switch Circ Low
P2777 Upshift Switch Circ Hi
P2778 Upshift Switch Circ Interm/Erratic
P2779 Downshift Switch Circ Range/Perf
P2780 Downshift Switch Circ Low
P2781 Downshift Switch Circ Hi
P2782 Downshift Switch Circ Interm/Erratic
P2783 Torque Conv Temp Too Hi
P2784 Input/Turbine Speed Sens A/B Correlation
P2785 Clutch Actuator Temp Too Hi
P2786 Gear Shift Actuator Temp Too Hi
P2787 Clutch Temp Too Hi
P2788 Auto Shift Manual Adaptive Learning at Limit
P2789 Clutch Adaptive Learning at Limit
P2790 Gate Select Direction Circ
P2791 Gate Select Direction Circ Low
P2792 Gate Select Direction Circ Hi
P2793 Gear Shift Direction Circ
P2794 Gear Shift Direction Circ Low
P2795 Gear Shift Direction Circ Hi
Old Mar 10, 2009 | 09:30 PM
  #29
Pyro's Avatar
Pyro
I Beat Tetris
P2A00 - P2A99
P2A00 O2 Sens Circ Range/Perf Bank1 Sens1
P2A01 O2 Sens Circ Range/Perf Bank1 Sens2
P2A02 O2 Sens Circ Range/Perf Bank1 Sens3
P2A03 O2 Sens Circ Range/Perf Bank2 Sens1
P2A04 O2 Sens Circ Range/Perf Bank2 Sens2
P2A05 O2 Sens Circ Range/Perf Bank2 Sens3
Old Mar 10, 2009 | 09:31 PM
  #30
Pyro's Avatar
Pyro
I Beat Tetris
P3400 - P3499
P3400 Cylinder Deactivation Sys Bank1
P3401 Cylinder 1 Deactivation/Intake Valve Ctrl Circ/Open
P3402 Cylinder 1 Deactivation/Intake Valve Ctrl Perf
P3403 Cylinder 1 Deactivation/Intake Valve Ctrl Circ Low
P3404 Cylinder 1 Deactivation/Intake Valve Ctrl Circ Hi
P3405 Cylinder 1 Exhaust Valve Ctrl Circ/Open
P3406 Cylinder 1 Exhaust Valve Ctrl Perf
P3407 Cylinder 1 Exhaust Valve Ctrl Circ Low
P3408 Cylinder 1 Exhaust Valve Ctrl Circ Hi
P3409 Cylinder 2 Deactivation/Intake Valve Ctrl Circ/Open
P3410 Cylinder 2 Deactivation/Intake Valve Ctrl Perf
P3411 Cylinder 2 Deactivation/Intake Valve Ctrl Circ Low
P3412 Cylinder 2 Deactivation/Intake Valve Ctrl Circ Hi
P3413 Cylinder 2 Exhaust Valve Ctrl Circ/Open
P3414 Cylinder 2 Exhaust Valve Ctrl Perf
P3415 Cylinder 2 Exhaust Valve Ctrl Circ Low
P3416 Cylinder 2 Exhaust Valve Ctrl Circ Hi
P3417 Cylinder 3 Deactivation/Intake Valve Ctrl Circ/Open
P3418 Cylinder 3 Deactivation/Intake Valve Ctrl Perf
P3419 Cylinder 3 Deactivation/Intake Valve Ctrl Circ Low
P3420 Cylinder 3 Deactivation/Intake Valve Ctrl Circ Hi
P3421 Cylinder 3 Exhaust Valve Ctrl Circ/Open
P3422 Cylinder 3 Exhaust Valve Ctrl Perf
P3423 Cylinder 3 Exhaust Valve Ctrl Circ Low
P3424 Cylinder 3 Exhaust Valve Ctrl Circ Hi
P3425 Cylinder 4 Deactivation/Intake Valve Ctrl Circ/Open
P3426 Cylinder 4 Deactivation/Intake Valve Ctrl Perf
P3427 Cylinder 4 Deactivation/Intake Valve Ctrl Circ Low
P3428 Cylinder 4 Deactivation/Intake Valve Ctrl Circ Hi
P3429 Cylinder 4 Exhaust Valve Ctrl Circ/Open
P3430 Cylinder 4 Exhaust Valve Ctrl Perf
P3431 Cylinder 4 Exhaust Valve Ctrl Circ Low
P3432 Cylinder 4 Exhaust Valve Ctrl Circ Hi
P3433 Cylinder 5 Deactivation/Intake Valve Ctrl Circ/Open
P3434 Cylinder 5 Deactivation/Intake Valve Ctrl Perf
P3435 Cylinder 5 Deactivation/Intake Valve Ctrl Circ Low
P3436 Cylinder 5 Deactivation/Intake Valve Ctrl Circ Hi
P3437 Cylinder 5 Exhaust Valve Ctrl Circ/Open
P3438 Cylinder 5 Exhaust Valve Ctrl Perf
P3439 Cylinder 5 Exhaust Valve Ctrl Circ Low
P3440 Cylinder 5 Exhaust Valve Ctrl Circ Hi
P3441 Cylinder 6 Deactivation/Intake Valve Ctrl Circ/Open
P3442 Cylinder 6 Deactivation/Intake Valve Ctrl Perf
P3443 Cylinder 6 Deactivation/Intake Valve Ctrl Circ Low
P3444 Cylinder 6 Deactivation/Intake Valve Ctrl Circ Hi
P3445 Cylinder 6 Exhaust Valve Ctrl Circ/Open
P3446 Cylinder 6 Exhaust Valve Ctrl Perf
P3447 Cylinder 6 Exhaust Valve Ctrl Circ Low
P3448 Cylinder 6 Exhaust Valve Ctrl Circ Hi
P3449 Cylinder 7 Deactivation/Intake Valve Ctrl Circ/Open
P3450 Cylinder 7 Deactivation/Intake Valve Ctrl Perf
P3451 Cylinder 7 Deactivation/Intake Valve Ctrl Circ Low
P3452 Cylinder 7 Deactivation/Intake Valve Ctrl Circ Hi
P3453 Cylinder 7 Exhaust Valve Ctrl Circ/Open
P3454 Cylinder 7 Exhaust Valve Ctrl Perf
P3455 Cylinder 7 Exhaust Valve Ctrl Circ Low
P3456 Cylinder 7 Exhaust Valve Ctrl Circ Hi
P3457 Cylinder 8 Deactivation/Intake Valve Ctrl Circ/Open
P3458 Cylinder 8 Deactivation/Intake Valve Ctrl Perf
P3459 Cylinder 8 Deactivation/Intake Valve Ctrl Circ Low
P3460 Cylinder 8 Deactivation/Intake Valve Ctrl Circ Hi
P3461 Cylinder 8 Exhaust Valve Ctrl Circ/Open
P3462 Cylinder 8 Exhaust Valve Ctrl Perf
P3463 Cylinder 8 Exhaust Valve Ctrl Circ Low
P3464 Cylinder 8 Exhaust Valve Ctrl Circ Hi
P3465 Cylinder 9 Deactivation/Intake Valve Ctrl Circ/Open
P3466 Cylinder 9 Deactivation/Intake Valve Ctrl Perf
P3467 Cylinder 9 Deactivation/Intake Valve Ctrl Circ Low
P3468 Cylinder 9 Deactivation/Intake Valve Ctrl Circ Hi
P3469 Cylinder 9 Exhaust Valve Ctrl Circ/Open
P3470 Cylinder 9 Exhaust Valve Ctrl Perf
P3471 Cylinder 9 Exhaust Valve Ctrl Circ Low
P3472 Cylinder 9 Exhaust Valve Ctrl Circ Hi
P3473 Cylinder 10 Deactivation/Intake Valve Ctrl Circ/Open
P3474 Cylinder 10 Deactivation/Intake Valve Ctrl Perf
P3475 Cylinder 10 Deactivation/Intake Valve Ctrl Circ Low
P3476 Cylinder 10 Deactivation/Intake Valve Ctrl Circ Hi
P3477 Cylinder 10 Exhaust Valve Ctrl Circ/Open
P3478 Cylinder 10 Exhaust Valve Ctrl Perf
P3479 Cylinder 10 Exhaust Valve Ctrl Circ Low
P3480 Cylinder 10 Exhaust Valve Ctrl Circ Hi
P3481 Cylinder 11 Deactivation/Intake Valve Ctrl Circ/Open
P3482 Cylinder 11 Deactivation/Intake Valve Ctrl Perf
P3483 Cylinder 11 Deactivation/Intake Valve Ctrl Circ Low
P3484 Cylinder 11 Deactivation/Intake Valve Ctrl Circ Hi
P3485 Cylinder 11 Exhaust Valve Ctrl Circ/Open
P3486 Cylinder 11 Exhaust Valve Ctrl Perf
P3487 Cylinder 11 Exhaust Valve Ctrl Circ Low
P3488 Cylinder 11 Exhaust Valve Ctrl Circ Hi
P3489 Cylinder 12 Deactivation/Intake Valve Ctrl Circ/Open
P3490 Cylinder 12 Deactivation/Intake Valve Ctrl Perf
P3491 Cylinder 12 Deactivation/Intake Valve Ctrl Circ Low
P3492 Cylinder 12 Deactivation/Intake Valve Ctrl Circ Hi
P3493 Cylinder 12 Exhaust Valve Ctrl Circ/Open
