33x12 is gonna require some serious hacking, and new wheels... im running the 2in kit and tires that are roughly 32x11 and they BARELY fit without rubbing, actually i think they may just barely clip the inner fender a teeny bit.
Quote:
33's and only a leveling kit, no dice. This thread will help you out.Originally Posted by broke33
So with the leveling kit we can 33x12 no problem. Can we go bigger or wider with the body lift or is the body lift a waste of money? I have a TRX4 2010 and wonder what trimming I will need to do with the flares to fit the tires?
The OFFICIAL Lift and Tire Size Thread
I believe Donkeypunch is running 285s with just the leveling kit but they are no 12inches wide haha... and he had to do some MAJOR cutting in the wheel wells
Quote:
not a chance.... on my 08, i had a 3'' body lift, and a modified leveling kit, originally the leveling kit was a 2'' but i modified it to probably a little over 2.5'' even with all that, i had to do quite a bit of hacking on the inner fender and the fender flares to clear the 33 12.50's and a 9'' wide 0 offset wheelOriginally Posted by broke33
King Jackass
Quote:
Oh yeah? Originally Posted by broke33
With my leveling kit and 33x11.2"s on a stock 16x7 25mm offset (= 5" of backspacing) I had cut out half of my inner fenders, completley remove the factory flaps, and cut the front bumper 3" up. Is your sentence a statement or a question?
I did test fit the same size tire with wheels that will clear the frame (16x8.5 -6mm offset =4.5" backspacing, but moves the side wall 1.25" because of the wheel width). This required more trimming than I have already done with the same size tire. To step up to a 33x12.5, it can be done.....but you will need to bust out the dremel and start removing some serious material.
