3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
so i just purchased some wheels for HIGH Life
Old Jul 9, 2011 | 08:10 PM
  #21
Eimer123's Avatar
Eimer123
Originally Posted by cope4jerd
ok i will post pics in a min but i need help please im trying to tell my roommate how to remove the mud guards on the front fenders. any suggetstions? PLEASE!
Check this out it should help explain.
http://www.jegs.com/InstallationInst...8-51908-02.pdf
Old Jul 9, 2011 | 09:07 PM
  #22
cope4jerd's Avatar
cope4jerd
Eimer Thanks a bunch! i forgot all about those instructions.... it hard to explain that to someone who is not very machanically gifted and also over thousands of miles away on an iPod facetime screen with service that keeps going in and out. it should help. im hoping she can get someone else over to just cut some more out of the original mudguard and possibly the inner fender guard so that the rubbing sound isnt as bad. wish i was home to do it.
Old Jul 9, 2011 | 09:51 PM
  #23
cope4jerd's Avatar
cope4jerd
YAY! so here's the improved HIGH Life with the new feet in the old shoes! IMAG0553.jpg?t=1310261745
Old Jul 9, 2011 | 10:37 PM
  #24
Eimer123's Avatar
Eimer123
Not to shabby! I cannot wait to do a body lift and shove 33's under my truck
Old Jul 9, 2011 | 10:57 PM
  #25
cope4jerd's Avatar
cope4jerd
thank you! they are rubbin a bit in the back thats why i had the urgent question earlier. hopefully i can get someone back home to do a temp fix till i can get home and do it right..... its also in need of a bath, a good waxin... and then some night shade and some plasti dipped areas. hmmmmm? money is having to be saved for now though... F'n Dvorce!
Old Jul 9, 2011 | 11:05 PM
  #26
Eimer123's Avatar
Eimer123
What is the offset on your wheels?
What size tires do you have?
Just a body lift?
Old Jul 10, 2011 | 11:44 AM
  #27
wingman_214's Avatar
wingman_214
Congrats, that's a nice looking truck.
Old Jul 10, 2011 | 07:28 PM
  #28
cope4jerd's Avatar
cope4jerd
Just a body lift?
ok wheels are Eagle Alloy 140 series 16x8 with 4.517in backspacing and a +2.00mm offset
Tires are Cooper Discoverer S/T, not STT's or the S/TC's (LT285/75/R16) N speed rating. diameter of 32.80in, section width of 11.30in, tread width of 9.20in. recomended wheel width is 7.50 - 9.00in. the tires are around 225.00 a piece but i got mine used for free!
3" PA body lift, 2" DayStar(i think) front leveling kit. no blocks in the rear. old crappy original rear shocks and old crappy original struts.
the guys in here are right though.... if you dont want rubbing issues stay as close to the +25mm OEM offset as possible. mine thankfully is rubbing only on the rear corner of the mudguard and not on the front bumber. but i know im cutting it close and it can get worse if i hit bumps while turning or corner too fast. next set of tires may have to be smaller?????? i'll show some pics here in a bit.
and thanks for the compliments ya'll! shes a work in progress!
Old Jul 10, 2011 | 07:36 PM
  #29
cope4jerd's Avatar
cope4jerd
here is where the rub is.
IMAG05581.jpg?t=1310262970
Old Jul 10, 2011 | 10:28 PM
  #30
Eimer123's Avatar
Eimer123
Meh just cut a little more off the plastic forget smaller tires.
