3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Factory remote start, time limit?
Old Nov 13, 2011 | 04:27 PM
Haas1962's Avatar
Haas1962
Default Factory remote start, time limit?
Ok, posted this in the wrong forum before. Trying now in the right forum.
Hey, gang,
I've got a 2008 Lariat trim with a 4.7 V-8. It has the factory remotestart on it. But a couple times now, I've started the truck via remote, checked and verified that it started, only to come out to the truck a number of minutes later to find that the truck is not running.
Is there a time limit set to how long it will run when started by remote?
If so, is there a way to adjust the time limit?
Thanks,
By the way, I gotta say, it's the first Dodge truck I've ever owned, and I'm now wondering why I didn't discover the fun of dodge trucks earlier.
Old Nov 28, 2011 | 08:06 AM
MitsuRaider's Avatar
MitsuRaider
I believe the remote starts will only keep ur ttruck on for 15 mins before you need to insert your key
Old Nov 28, 2011 | 08:35 AM
marcsnyder05's Avatar
marcsnyder05
As lghtngblt02 quoted in another thread about this
Your vehicle may be equipped with a remote starting system, which will allow the vehicle to be started from distances up to approximately 300 feet way from the vehicle using the remote keyless entry key fob which is part of your ignition key. In order to remote start your vehicle, the hood, and all the doors must be closed. To remote start your vehicle, press the REMOTE START button on the key fob twice within three seconds. To indicate that the vehicle is about to start, the parking lights will flash and the horn will sound briefly. Once the vehicle has started, the engine will run for 15 minutes. To cancel remote start, press the REMOTE START button once. To enter the vehicle while the engine is running during a remote start, you must first unlock the vehicle using the
UNLOCK button on the key fob. After the vehicle is unlocked, you have 60 seconds to enter the vehicle, insert the key in the Ignition and move it to the RUN position, otherwise the engine will cancel remote start and automatically turn off.
Remote start will also cancel if any of the following occur:
• If the engine stalls or RPM exceeds 2500
• Any engine warning lamps come on
• The hood is opened
• The hazard switch is pressed
• The transmission is moved out of park
• The brake pedal is pressed.
The vehicle can be started remotely up to a maximum of two times. The vehicle is also allowed a maximum of one failed start, where the remote start sequence was initiated but cancelled before the engine begins to crank. After either of these conditions, or if the Vehicle Theft Alarm is alarming, or if the PANIC button was pressed, the vehicle must be reset by inserting a valid key into the ignition and moving it to the RUN position, then back to LOCK. The parking lamps will remain illuminated to indicate that the vehicle has remote started and the engine is running. The lamps will turn off when the ignition is turned to RUN or the remote start is cancelled.
Old Nov 28, 2011 | 02:39 PM
MitsuRaider
yeah what he said
