3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
front lift and tires installed
Old Jul 16, 2012 | 05:54 PM
smitty21's Avatar
smitty21
I would difinetly find the torque specs, and re torque everything. and then get it alignment. Most kits require it as well.
Old Jul 16, 2012 | 08:25 PM
dsimm87's Avatar
dsimm87
ditto on the alignment. I put a 2.5" lift on the front and a 1.5" blocks in the back. I prefer the rake look, so if I were you, I'd put a 1" block in the rear, or helper springs.
Old Jul 17, 2012 | 10:07 AM
mopar204's Avatar
mopar204
Ill get an alignment as soon as possible, also it says 80 psi max for my tires but what should i really have in them? I dont hual anything and wont be doing any mudding really
Old Jul 17, 2012 | 06:51 PM
dakotaff's Avatar
dakotaff
80 psi is insane! Drop it to a reasonable amount, around 38psi.
Old Jul 17, 2012 | 07:14 PM
80 psi is way too much and it looks like you need at least a 2" block in the back to level it out. That 2" front kit really raised it!
Old Jul 17, 2012 | 08:44 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
yeah it did, holy crap..looks good though!
Old Jul 17, 2012 | 09:10 PM
rebel4055's Avatar
rebel4055
I have MasterCraft Couser MTs. I run 40 psi. No log truck feeling at 30mph haha.
Old Jul 18, 2012 | 01:33 AM
mopar204's Avatar
mopar204
Ok thanks, and i have the tires at about 50psi right now so ill drop it to about 35-40 psi
Old Nov 3, 2012 | 05:52 PM
aragon's Avatar
aragon
i am new here and i know this is an old thread but, MOPAR204 what leveling kit did you use? its a 2" and not a 2.5"? it looks pretty tall.. and are you 2wd and v6 or v8? thanks
Old Nov 3, 2012 | 08:41 PM
Reject's Avatar
Reject
I would say its a 2" kit, most people especially 4x4 avoid 2.5"+ Kits, as it wears parts quicker, and I believe can cause CV Bind (on 4x4)
I installed a 1.5" In my 2wd, along with new Monroe Reflex Struts and it brought the front up about 2-2.5"
When I see this truck, Makes me think to myself "Go buy solid black Rims already, Moron" Then Id just have to paint my Aluminum Rack, and its all blacked out.
