3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Oilin' the door
Old Sep 6, 2012 | 04:14 PM
JoeyDMG's Avatar
JoeyDMG
Default Oilin' the door
So, my passenger door started squeaking/groaning... according to the manual it says to use mopar motor oil and it seemed to get rid of the sound (I took a half bottle of oil I had left from my last oil change and a 1" paintbrush and brushed it on). The auto parts store said to use white lithium grease on it... I've never saw a thick grease on the door hinges when I got it. Which do you use or do you use something completely different?
Old Sep 6, 2012 | 04:19 PM
06Dak4.7Silver's Avatar
06Dak4.7Silver
I have white lithium grease sprayed on all my door hinges..just what I learned a couple years ago and how I do it. My doors (4) are silent!
Old Sep 6, 2012 | 04:55 PM
dakotaff's Avatar
dakotaff
I used some kind of grease a while ago and haven't heard a peep out of it since. It's the same grease I put on the rear of my wheels to prevent it from sticking, I can't remember the name of out right now. And I'm sure any oil would work as well as Mopar oil if you went that route.
Old Sep 6, 2012 | 05:58 PM
Robk1971's Avatar
Robk1971
I've used lithium grease, motor oil, or trans fluid. One thing I have to add on my experience with this trucks door hinges is this: When I bought my truck, the check roller on the rear drivers side door was completely seized. I tried all kinds of penetrating oils and grease to free it up and it wouldn't.
I ended up replacing he hinge for about $50 - $60. Then the truck sat most of last winter and I didn't use that door much even when I did drive the truck. I noticed that the check roller on the new hinge was starting to stiffen up as well. Lately I've been using the truck a lot and all doors have been getting used regularly with out hinge problems. So it seems that lack of use may not be a good thing on them either.
Old Sep 7, 2012 | 04:59 PM
JoeyDMG's Avatar
JoeyDMG
Yeah it was actually chevron oil... I am thinking the motor oil would attract dirt so next time I'll put some white lithium on 'em.
Old Sep 7, 2012 | 05:22 PM
Holbrook.Jeremy's Avatar
Holbrook.Jeremy
White lithium attracts dirt and crud as well. It's still what I used on my doors and for the most part they are noise free but it looks filthy all around the hinges because I SOAK them.
Old May 18, 2013 | 08:15 PM
JoeyDMG's Avatar
JoeyDMG
So I tried white lithium grease and it came back... I took a rag and wiped the hinges down and tried 3 in 1 oil... not sure if it's gone away. It seems to be squeaking from the round wheel on the top hinge.
Old May 20, 2013 | 01:21 PM
JoeyDMG's Avatar
JoeyDMG
So it would squeak when the door would open over the last "bump" on the hinge. I hit it with penetrating oil and it's not doing it at the moment...
