3rd Gen Dakota general discussion This section is for general discussions about your 3rd gen Dakota. Non tech related Dakota threads belong here.
Power window issues
Old Jun 5, 2018 | 08:43 PM
Cheapskate's Avatar
Cheapskate
Default Power window issues
I have a 2005 four door dakota and all the windows work except front passenger. It will not roll up or down from either it's own switch or the drivers switch. Any help would be appreciated.
Old Jun 8, 2018 | 10:40 PM
dodgeman1977's Avatar
dodgeman1977
There were some issues with some trucks with the passenger window, mine included, where the window was slow. There was a TSB for it, but I didn´t get it done. I have taken the door panel off and lubricated the tracks, which helped, but its still not right. The door panel is pretty simple to remove if you want to investigate the issue. Could be a power issue, motor issue, or track jammed, hard to say right now. When you hit the button, can you hear the motor trying to run?
Old Jun 10, 2018 | 02:07 AM
daktwos's Avatar
daktwos
Could be just a broken cable on the regulator or perhaps a dead motor.Remove door panel to have a look.Replacement is a very straightforward process.
