Bleeding Brakes
Old Apr 8, 2007 | 03:34 PM
tcv's Avatar
tcv
Default Bleeding Brakes
Is bleeding the brakes with a ABS system the same as none ABS?
Normally I just connect some surgical tubing to the brake bleed fitting (the other end of the surgical tubing is resting at the bottom of a 1/2 gallon container) and manually pump the brakes, adding fluid and pumping the brakes some more until the fluid coming out is good and clean and free of air. Not sure I can do the same with a ABS equiped system.
Tom
Old Apr 8, 2007 | 03:47 PM
Altair's Avatar
Altair
Dak attack!
Default RE: Bleeding Brakes
Just took a look in the service manual, that's how they recommend doing it so I don't think the ABS will be a problem:
Old Apr 9, 2007 | 01:48 AM
tcv's Avatar
tcv
That is great! Thanks....
Tom
Old Apr 9, 2007 | 02:36 AM
Altair's Avatar
Altair
Dak attack!
No problem, I got it from the service manual pdf. There's a sticky to download it at the top of the forum if you want it.
