Transfercase question
Old Apr 12, 2007 | 12:55 PM
Cuban11182's Avatar
Cuban11182
Default Transfercase question
How do I determine which transfercase I have on my Raider. It is the Duracross V8 Auto. THanks
Old Apr 12, 2007 | 02:00 PM
Casper50's Avatar
Casper50
Default RE: Transfercase question
Are you just wondering if your transfercaseis4wd or awd? If that's your question then it is 4wd. I'm not sure what else you are asking for but if that's not it let me know.
Old Apr 12, 2007 | 02:51 PM
Cuban11182's Avatar
Cuban11182
I just realized i have the first one since i dont have AWD
TRANSFER CASES
NV233HD
[ul][*]Availability: Standard[*]Shift Mechanism: Electrical/electronic[*]Operating Modes: Neutral; 2WD; 4WD High, locked; 4WD Low, locked[*]Low Range Ratio: 2.72[*]Center Differential: None [/ul]
NV244HD
[ul][*]Availability: Optional on SLT and Laramie[*]Shift Mechanism: Electrical/electronic[*]Operating Modes: Neutral; 4WD High, full-time; 4WD High, locked; 4WD Low, locked[*]Low Range Ratio: 2.72[*]Center Differential Type: Planetary with lock[*]Torque Split, F/R: 48/52 [/ul]
